Model Boat Mayhem - Forum
Author Topic: Build the Bismarck - a "Hachett" job?  (Read 216059 times)
Down below
Re: Build the Bismarck - a "Hachett" job?
« Reply #625 on: August 13, 2007, 04:57:25 PM »
Martin
Serves you right for getting all hot under the collar about your deliveries and hachette came good ;D
Grrrrrrr that serves us right for having a laugh as it also seems you are now two issues in front of everyone else as issue 25 does not go on sale until Weds this week and you have been sent up to iss 26 :'(
Wont be hearing from you for a while then 8)
Maybe by the time you have completed that little lot issue 27 might have turned up ;D
« Last Edit: August 13, 2007, 05:06:40 PM by Down below »
colin-stevens
« Reply #626 on: August 13, 2007, 05:51:22 PM »
get the glue out and get a move on, not forgetting the camera of course.
have fun.
colin
grumpy old XXX
R2-D2
« Reply #627 on: August 13, 2007, 06:01:37 PM »
How about a web Cam ?
   Call it the Matinsbissy or bizzy cam as he always is .!
  Luke
colin-stevens
« Reply #628 on: August 13, 2007, 06:23:58 PM »
gets my vote, and was going to be cruel, but, wont. leave that to everyone else.
colin
grumpy old XXX
« Reply #629 on: August 13, 2007, 06:53:25 PM »
Busy?!?!?  This is my average work speed..... ask Jan!  ::)
"This is my firm opinion, but what do I know?!"   -  http://www.modelboatmayhem.co.uk/
Down below
« Reply #630 on: August 13, 2007, 08:11:51 PM »
Must have been taken whilst waitin for the mags ;)
Cargo
« Reply #631 on: August 13, 2007, 10:14:27 PM »
Hehehe...
... but it was at last a qualified build... if he was awake  ;D
« Last Edit: August 14, 2007, 09:51:54 AM by Mayhem - Forum Admin »
rem2007
« Reply #632 on: August 14, 2007, 12:24:44 AM »
nice pic martin, don't slip off mate you could hurt yourself. anyway I'm just finishing week 12 and getting the hang of steaming and using a combination of pins and planking clamps. getting more confidence from all you other pros. well off to la  land
nite all
robert
« Reply #633 on: August 14, 2007, 09:12:33 AM »
Hi Robert,
Are you chamfering the planks for a better fit?
Is anybody?
Down below
« Reply #634 on: August 14, 2007, 09:47:32 AM »
Yep me is as cant rely on the 2nd planking to seal any mishaps ;)
mark_1984
« Reply #635 on: August 14, 2007, 10:11:02 AM »
Yup - me too :)  little effort with some 80 grit emery glued to a sanding block.  Have a look on my web site - it's a great tool
www.buildthebismarck.co.uk
rem2007
« Reply #636 on: August 14, 2007, 05:22:42 PM »
sir, yes sir camphered and polished......and if it moves salute it an if it dont move paint it!
robert
Down below
« Reply #637 on: August 14, 2007, 07:43:59 PM »
Am lucky enough to have a Dremel detail sander that has loads of moulded heads for awkward sanding detail and takes the pain out of sanding, just a shame I cant find a tool just as fast for the planking as not looking forward to the 2nd round :-\
Down below
« Reply #638 on: August 14, 2007, 08:31:37 PM »
Martin
Just a thought, would it not be wise to mount your ply motor blocks in a way so that the motors can be removed if need be shoud one of them dies a death?
As if you simply epoxy the mount blocks into place on the hull getting a motor out could well be a nightmare ;)
« Reply #639 on: August 14, 2007, 08:48:19 PM »
Not thought that far ahead yet.
I might just use V blocks silicon sealant and a couple of springs..... nice and quiet.
Martin
Down below
« Reply #640 on: August 15, 2007, 08:25:16 AM »
Well posh ;)
marki53
« Reply #641 on: August 15, 2007, 04:54:48 PM »
Martin
no problem, motors are simply screwed to the bracket
already had to dismount the motors for treating the inside of the hull with pore filler...
cheers
markus
« Last Edit: August 15, 2007, 05:01:25 PM by marki53 »
« Reply #642 on: August 15, 2007, 05:35:51 PM »
Hi Marki,
The only reason I say that is I don't know what parts of the deck will be removeable yet.
Lift off motors in V block is the easiest I can think off..... unless some else knows a better idea.....  ;D
« Last Edit: August 15, 2007, 05:40:52 PM by Mayhem - Forum Admin »
Down below
« Reply #643 on: August 15, 2007, 07:47:12 PM »
Martin
cheers
markus
This is what I was saying, the motors are simply screwed to the ply bracketsl in your assembly and the brackets are then glued to the hull with epoxy are they not?
It may be later difficult to access the removal of the motors from these brackets due to poor access and so he wont be able to remove the brackets from the hull either as they will have been glued to the hull.
This is why Martin is talking of a removable arrangement as if the access is restricted to the motors even with the removable deck then it will be fun getting the motors out if need be.
If you think it will be okay then fine, but if there is a chance it is not then it is a mess to put right later ;)
« Reply #644 on: August 15, 2007, 09:54:29 PM »
Just looking back on the deck structure, it looks like the whole deck comes of in two sections.
The rear sections looks like it goes back way pass the Motors, so motor removal shouldn't be a problem.
As say not sure yet, I'll cross that bridge when I need to!  ;D
slewis
« Reply #645 on: August 15, 2007, 09:57:55 PM »
Q here .
Whats that in the polystyrene block ?
Cargo
« Reply #646 on: August 15, 2007, 10:42:50 PM »
Dynamite, if the english model-battle-cruisers cant sink his boat  ;D ;)
No, he has placed his batteries in there  :)
slewis
« Reply #647 on: August 15, 2007, 10:45:41 PM »
 ;D ;D ;D ;D ;D I like your style mate !!
Shane
Down below
« Reply #648 on: August 16, 2007, 08:02:43 AM »
The scews that secure the motor's to the ply blocks might be hard to access with a screw driver as then run horizontally and not vertically, not much room between the servo rib and the screw head, maybe 3" at most but suppose it can be done ;)
marki53
« Reply #649 on: August 16, 2007, 10:05:30 AM »
i use a shortened screwdriver for that
but i'ts still a bit fiddy...
markus
Pages: 1 ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 ... 56   Go Up
