Model Boat Mayhem - Forum
Author Topic: Build the Bismarck - a "Hachett" job?  (Read 210779 times)
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: Build the Bismarck - a "Hachett" job?
« Reply #805 on: October 18, 2007, 09:47:30 PM »
I have read every post on this build and at different sections all have stated to build light if possible, so far what I have received in the packs is almost double the weight of the balsa, so therefore it must be lighter and should sail better..
As for not having the strength, I fail to see why not, as it will be built the same and double planked in balsa then given fibreglass matt and resin on the hull which I would be doing whether it is ply or balsa, I have yachts which are A Class built entirely from balsa and are 1.8 metres long and have been happily sailing them for years with no problems, so I think the strenght issue is non existant.........
Roy
mark_1984
« Reply #806 on: October 19, 2007, 05:44:34 AM »
Hi Roy,  There is little you can't achieve with some inginuity.  I'll look forward to hearing how you get on.
Mark
Peter Fitness
« Reply #807 on: October 19, 2007, 07:27:35 AM »
Roy, go for it mate. One of our club members has built several large battleships, around the 2.5 metre mark, using balsa covered with fibreglass with no problems at all.
Peter
I'm the boss in our house, my wife said I could be.
Theres_your_problem!
  • Ship mate
  • ...don't get me started!
« Reply #808 on: October 19, 2007, 10:38:51 AM »
You could try photocoping the parts if possible, then you could cup out and reproduce in almost any size or material.... might be breech of copyright though.
anmo
  • That's unpossible!
« Reply #809 on: October 19, 2007, 11:19:45 AM »
I don't think there would be any copyright problem as long as it's purely for your own use, you aren't copying any of the parts to sell, or pass on to someone else. That's UK copyright law though, they may have something a bit different out in the far-flung ex-colonies, though I can't envisage anyone from Hatchette or Amati traveling all that way to impound your Bismarck copy. Like most kits I've seen, this one seems to be massively over engineered and over complicated, never go the simple route and use one piece of wood where you can fit in three or four smaller ones, so if you use some common sense and do it right, you could end up with something much better than the original, at least as far as the hull is concerned.
Down below
« Reply #810 on: October 19, 2007, 02:34:18 PM »
Roy
Each to there own, sounds a lot of hassle to me, it will be very interesting to see how you get on and am sure Amati will be watching closely too as you seem to know something they dont about this model.
« Reply #811 on: October 19, 2007, 09:08:49 PM »
Question:
I was under the apprehension that there is / was a 2nd layer of planking but it seem that the 2nd layer is not over the top but just 'around the top' ie. just under the deck - is that correct?
Second question:
If there is only one layer of planking around the main bulk of the hull, when do I start thinking about smoothing out the hull and prepping it for weatherproofing?
« Last Edit: October 20, 2007, 12:15:46 PM by Forum Admin - Martin »
"This is my firm opinion, but what do I know?!"   -  http://www.modelboatmayhem.co.uk/
mark_1984
« Reply #812 on: October 20, 2007, 02:07:33 AM »
Hi Martin,
The majority of the hull does have a second payer of planking.  In fact all of it except the recessed bit just under the deck.
Don't do anything about waterproofing the outside until the second layer of planking is completed.  Any waterproofing you do on the first layer of planking will just stop the second layer of planking from being glued properly, and wont achieve anything.  Water shouldn't get past the paint/waterproofing on the very outside of the hull.
This link shows you what the Germans have received up to date.  It may (or may not) help.  The second layer planking starts at issue 35.
http://www.subifa.de/heftvorschau/die_bismarck_aktuell.htm
Mark
The long Build
« Reply #813 on: October 23, 2007, 11:41:27 PM »
Hi Martin
Did you start getting your issues of the "Build The Bismark" at the start or did you start your subscription a bit later, as a friend of mine who is also building this is up to issue 34-35 and well into the structure like the German site .  Just wondered...
By the way looks it looks nice , I got the first issue but then thought against it..wish I had gone for it now... although to much on now so maybe right decision
« Reply #814 on: October 24, 2007, 04:21:51 PM »
I started my subscription about 3 or 4 weeks in, a few teething problems with the delivery of a few issues but soon sorted out.
I've just received issues 29-32 with a binder and a DVD!
.... this wood stuff will never catch on!
stevenrichie
    • cadma.info
« Reply #815 on: November 05, 2007, 07:14:14 PM »
Hi Martin,
I was beginning to think i was the only modeller who was prepared to shell out this sort of money on a weekly magazine project just for curiosity reasons!!
It has been very interesting looking how far you have gone building the Bismarck,i am just about finishing the planking ready to sort the decks,I think it is going to be money well spent.
I will keep checking to see how you are doing [so i can learn from your build]
Keep up the good work,
Steve Richie CADMA
« Reply #816 on: November 05, 2007, 10:50:31 PM »
Hi Steve, how did your planking go?
Martin
Down below
« Reply #817 on: November 09, 2007, 02:03:25 PM »
Hey Martin hows the build going?
Have you seen the German previews & build re the deck planking yet?
The supplied stuff looks awful, its out of scale, the plank lines look too thick and the qty looks wrong compared to the actual ship, never mind the differing shades of part supplied, it wont match from structure to structure!
Seems they have supplied a printed deck outline on a panel rather than supplying what they advertised as it having thin laser cut limewood deck planks.
Iss 61 deck part has a poor print registration in that the plank line on the curve to the right runs out :o
Even there supplied RC set does not include the parts the originally advertised, they show three prop shafts and send two let alone showing plastic rudders that turn out to be self assembly laminated ply versions, wish I knew that magician {-)
Am starting to loose patience big style with this kit >>:-(
« Last Edit: November 09, 2007, 02:07:19 PM by Down below »
Maikiro
« Reply #818 on: November 15, 2007, 01:18:29 PM »
Hey All, I see some peeps down under dont have issue one yet.
If you dont then send me a Message with address and I will send the only spare issue one copy I have. It will be missing a paintbrush and 'rubbish' glue, other than that it does have the magazine and parts... :)
« Reply #819 on: November 17, 2007, 01:43:29 AM »
tjilpi
« Reply #820 on: November 18, 2007, 09:24:16 PM »
Greetings Saw-dust Fans,
Way down here in the wrong half of the world we're just looking at Part 11 (planking) and laughing hysterically. With all the spitz und sparkz from the German site about the model, can anyone condense into a series of dot points what they think is wrong with the model? I see a couple of paragraphs running "Ach, if only I'd known that at part xx, I would have mounted it backvords!!" etc, all in a heavy Teutonic accent and I thought I'd try to incorporate this advise.
Oz
« Reply #821 on: November 18, 2007, 09:44:41 PM »
Use waterproof PVA glue. - You could also use a thick superglue,  very quick!
Don't bother with the internal PVA and gauze thing - I would recommend using a spray varnish / paint to seal the internals.
Shape the plank edges so they fit alongside each other closer.
Shape / contor the ribs so the hull planks are glued to a flat surface.
Decide early on what motor setup you will be using.
Number the parts before separating them, especially the ribs / bulkheads.
tjilpi
« Reply #822 on: November 18, 2007, 09:56:28 PM »
Thanx mate,
On reading through I see several summations and I'll thank the people individually (when I remember to take note  :embarrassed: ). You mention 'which motor setup. I mean to r/c the model, the setups will probably be covered in the previous 40-odd pages but could you give me a brief rundown on the variations here please?
Double Cheers
Oz
ps. you guys are great  O0
« Reply #823 on: November 19, 2007, 02:09:47 PM »
As you probably knew already , the Bismarck had 3 propellers.
Hatchet are offering a 2 motor setup utilizing motors with gearboxes.
Apparently Hachett will be detailing a two motor installation with dummy 3rd / middle propeller.
I will be using a 2 motor setup but using Graupner parts as supplied by marki53 from Germany.
A third, working centre shaft can be fitted but this will require extensive reworking of the hull and frameworks  - and your on your own if you want to do that! (Marki53 supplies both 2 & 3 motor setups )
http://www.modelboatmayhem.co.uk/forum/index.php?topic=2830.msg51244#msg51244
Down below
« Reply #824 on: November 21, 2007, 03:53:09 PM »
tjilpi
« Reply #825 on: November 22, 2007, 12:41:33 AM »
Addressed mainly to the Aussies in the crew, the only truly waterproof PVA I can find is 'Great Planes' Aliphatic Resin Glue, this dries 'clear-ish' with a yellow tint. Does anyone have a better choice?
Oz
jock
  • It ain't a hobby if you have to Hurry
« Reply #826 on: November 22, 2007, 01:47:12 AM »
I'm using vice grip a waterproof pva.
Jock
Jock
Peter Fitness
« Reply #827 on: November 22, 2007, 09:48:07 PM »
Oz, I always use Aquadhere Exterior, which claims to be waterproof. So far I have not had any problems, but I always coat the finished model with fibreglass resin before painting, which certainly keeps water out.
Peter.
tjilpi
« Reply #828 on: November 23, 2007, 08:44:04 AM »
Just wanted to say to Martin - "Brilliant effort mate!". Just like being there really ... but I can't see how you got ALL that sanding (pre issue 11) done in one frame?! I mean really, shouldn't it be sanding; entries 1 to 26?
Oz
« Reply #829 on: November 23, 2007, 09:08:55 AM »
 >>:-(   Sanding makes me angry!   >>:-(
Don't ask me for anything after a length hull sanding session!   >:(
And on top of that the 2nd layer of planking arrived this week....  :'(
tjilpi
« Reply #830 on: November 26, 2007, 09:54:03 PM »
G'day all (or as my PTI used to say after the 5km run in kit "Are we having fun yet?"),
On motors and setup, does anyone know at what issue Hatchett say "Ok, drop the motors in"? or when and where to fit the r/c? or do those instructions come with the package of props,tubes and motors?
For those that apt for Marki's motors, have you thought of the electronics to go with them yet?
Oz
mark_1984
« Reply #831 on: November 27, 2007, 02:32:55 AM »
I think fitting instructions come with the RC kit, which should be delivered about the same time as issue 58.
I understand that the prop shafts are 6mm tubes, 4mm shafts.  The smart money would be on sanding out the cut outs in the frames before planking the hull.
« Reply #832 on: November 27, 2007, 09:01:38 AM »
I'm going for a straightforward electronics setup;
2 small speed controllers
(Mtronics MicroVIPER Marine10),
4 to 6 channel receiver,
possibly a rudder / motor mixer,
possibly rotating turrets!  O0
  • Ship mate
  • North wales
« Reply #833 on: November 27, 2007, 10:23:32 PM »
Martin are you slaking as no update on your build since the 17th of Nov tut tut tut >>:-(
No Motor is to Big for me.....Catch it if you can Phil
Cargo
« Reply #834 on: November 27, 2007, 10:25:24 PM »
And what about the rest of the puffer-build update on mayhem?  {-)
  • Ship mate
  • North wales
« Reply #835 on: November 27, 2007, 10:46:35 PM »
Hasnt he finished that by now O0
Wetwater
  • My mind often wanders. Once it left completely.
« Reply #836 on: November 27, 2007, 10:56:00 PM »
    Don't get Martin started on puffers.  He'll never stop.   ::)   :D   {-)
Alan.
« Reply #837 on: November 28, 2007, 12:29:33 AM »
Started the superstructure last week but not had time to post the updates just yet.
The upper work are a series of nice little well thought out kits....
Down below
« Reply #838 on: November 28, 2007, 08:18:24 AM »
It appears Hachette have a new partwork series on there hands in time for as Christmas TV launch
Anyone fancy planking this {-) {-) {-)
http://www.rmweb.co.uk/forum/viewtopic.php?p=187471
djrobbo
« Reply #839 on: November 28, 2007, 09:55:51 AM »
Surely that should be in the steam section :D :D :D
