Can you slack the jibsheet to reduce weather helm in a gust?
Whoops, I wrote this BACKWARDS! To reduce weather helm, one needs to slack the Mainsheet. Or, tighten the jibsheet, or do both. Sorry.
Sloops can be harder to manage than squareriggers when the vessel turns into the wind due to excessive heel: The long boom of the mainsail will hit the water, limiting the skippers ability to spill wind from the mainsail. I see this all the time with my sandbagger sloop. But squaresails can be squared in, spilling wind, even if the lower yards are in the water. I see this (with barque Pamir and brig-rigged Aldebaran) whenever I carry too much sail for the wind/gusts, and have to contend with a knockdown or near knockdown. The heel of a moving vessel automatically turns the bow into the wind due to the asymmetric thrust of the bow wave.
When designing a hull/keel to match the scale sails and scale mast locations, I try to align the Dynamic Center of Effort of the sails (dCE) and the Dynamic Center of Lateral Resistance of the hull+keel+rudder (dCLR). When the centers are aligned, the rudder is most effective.
Many builders don't appreciate that the static CE/CLR is not in the same place as the dynamic CE/CLR. When the ship is moving, the dynamic centers rule, not the static centers. While the static values are at the geometric centers, the dynamic values are shifted forward to the 1/4 chord point. Example: static value for a 4 ft hull CLR is at the center, ie 2 ft aft of the bow. But the dynamic CLR is only 1 foot aft of the bow. This is per aviation practice; since sails and hulls and keels operate as lifting bodies, anything you know about airplanes will help you fix boat balance/maneuverability problems.
The common method used by modelers to find the CLR is to push the hull sideways. Where their finger is placed to get the boat to move w/out turning is the Static CLR. Now, to find the dynamic CLR, measure from the bow to your finger, and cut that distance in half. This will give you the 1/4 chord point, a good starting place for your endeavour to get the CE lined up with the dCLR. dCLR can be anywhere from 1/4 to 1/3 chord point, per aviation experience. Its never at the 1/2 chord point, though, which I've seen gets builders in trouble if they don't know that.
