Having built several steam pumps and as I am now starting on another I thought that I would describe the machining process in case anybody fancied building one.
Her is a pic of a previous one and hopefully the one described will turn out the same.
The first thing that I start with is the main body casting, I fettle it by filing off all the molding flashes and then I clean up the base.
This is done by rubbing the casting on a large flat file until the base is clean,
Mark of the center line as per the DRG and center pop the cross lines.
Set the casting up in the 4- jaw with suitable packing and get the center pop to run true, a jig is made to fit over the eventual valve stop and all is trued up so that the center pop runs true, the base of the casting must be square to the center line of the lathe.
With center drill, drill the casting and then run a 1/2" dia drill straight thro' the casting and finish off by boring out to 9/16" bore.
You can if you wish ream the hole if you don't want to bore it.
After boring thro" you can then machine the end of the casting that supports the cylinder.
It's one of the most critical machining operation, if the end of the casting isn't square with the bored holes it will be very difficult when assembling to get the pump to run.
FINISHED CASTING.
END COVERS FOR CYLINDER.
Again it's important to file of all the casting flashes, catch the casting on the end that has to be eventually drilled and tapped in the 3- jaw, this allows you to machine down the thickness of the plate and leave enough metal on the register to turn it around and then machine the plate , drill and tap, turn down the boss for packing gland.
Turn the plate around and grip in 3- jaw you can then face off the plate and turn the register to fit the cylinder bore and reduce the end to 1/32" thk.
The next procedure is machining the cylinder and the end cover.
MACHINING CYLINDER.
This is a straight forward 4-jaw with packing procedure.
The cylinder casting requires that the molding flash is ether filed off or milled to give a reasonable flat finish.
The center lines can be marked on remembering that the face that goes to the end plate has to be true to the bore. this is identified by the drain valve bosses.
Once set up square the casting is bored thro" to size and faced this ensures that the bore is square to this end, the casting can then be turned around and the end faced to size, this ends squareness isn't so important as the other end.
The cylinder is set up in the mill to mill the top face to size, if a mill isn't available it can be filed.
The only other job is to machine the cylinder end which is as the other one already described.
TO BE CONTINUED.
George
