Author Topic: Darnell U47  (Read 3211 times)
nelsona
Darnell U47
« on: March 30, 2011, 04:42:01 pm »
Wouls anyone care to advise as to the length of the Darnell U47? Thanks in advance
Sub driver
Re: Darnell U47
« Reply #1 on: March 30, 2011, 05:03:04 pm »
From memory I think its around the 60 inch mark in length and about 4 inch beam minus the saddle tank area, but don't know the exact sizes.
Hope its of use
Regards Sub.
Subsonic Mike
Re: Darnell U47
« Reply #2 on: March 30, 2011, 05:10:25 pm »
Patrick Henry
Re: Darnell U47
« Reply #3 on: March 30, 2011, 06:05:22 pm »
I think you'll find that the original Darnell U-47 was a bit shorter and bit wider that the later U-570 was...not much, only a couple of inches or so in length, and maybe an inch wider in the beam.
A nice boat though, well worth buying if you find a good one.
nelsona
Re: Darnell U47
« Reply #4 on: March 30, 2011, 08:34:44 pm »
Thanks for the replies, a further question, would it be worth making a brass deck and tower for this model (U47) or just go with the mouldings?
Sub driver
Re: Darnell U47
« Reply #5 on: March 30, 2011, 08:49:19 pm »
a brass deck and brass tower would add top weight and make it unstable unless you use thin brass
 sheet or use etched sheet  and are quite skilled in brass work and keep things relatively light. you can buy some very detailed resin towers these days from various companies that will transform the model inc a brass deck too
nelsona
Re: Darnell U47
« Reply #6 on: April 01, 2011, 10:01:46 am »
Thanks Sub Diver, Could you name any of the firms who make the sid parts? I have taken possession of a Darnell hull,but it needs a lot of work!
Sub driver
Re: Darnell U47
« Reply #7 on: April 03, 2011, 11:27:22 pm »
Sure no problems.
www.dream-arts.de
A German site but also in English very good parts and resin towers etc worth a look.
Also Accuate Armour from Scotland do a resin tower for the Type V11 U-boat.    www.accurate-armour.com
click on products then naval then submarines.
www.engel-modellbau.de
 again a German site very good.
Hope there of use.
regards Sub.
