Model Boat Mayhem - Forum
Author Topic: One thing leads to another  (Read 572 times)
wartsilaone
« on: April 30, 2011, 01:47:41 PM »
I'm planning to make a fibre glass hull for my next project and as I've never done this before I wanted to practice making a plug. As you will see I got a bit carried away.
I decided to go through the whole process to learn how to convert a G/A plan into a 3D form.
I simplified the layers of the G/A plan and combined them into one.
The layers were then cut ready for glueing.
It would need a bit of tweaking for the full size model but I was confidant that I could do it again for real.
Trouble was I couldn't stop there.
And after a few hours I ended up with this.
Bryan Young
Re: One thing leads to another
« Reply #1 on: April 30, 2011, 06:47:47 PM »
Just how big...or small....is this thing?
I would guess that it's pretty small.....so why do you need to make a GRP mould/hull? Fine if you're thinking of going into a sort of batch production I suppose. But if your hull is as small as it appears to be, then why not just have it vac-formed?
Larger hull plugs are really wasteful of timber and are much easier/cheaper to make using the the old tried and proven plank on frame method. Then wreck it when removing it from the mould! BY.
Notes from a simple seaman
wartsilaone
« Reply #2 on: April 30, 2011, 06:52:40 PM »
It was just to practice making the shapes for the hull plug which would be made from foam and be about a metre long. The next thing I have to try is making a mould. If you read the post and looked closer at pictures your questions would have been answered.
« Last Edit: April 30, 2011, 07:11:12 PM by wartsilaone »
Bryan Young
« Reply #3 on: April 30, 2011, 09:39:15 PM »
Oops, sorry. All I could see was a model about 70 cm long.
If you want to "practice" making a proper "plug" may I kindly suggest you make something a bit bigger.
Part of the "art" in making a plug for making a GRP moulding is to get the smaller details incorporated. Can't really do that on what appears to be a 500ft long ferry/liner.
As I said. At that scale vac-forming is probably your best bet. BY.
wartsilaone
« Reply #4 on: April 30, 2011, 10:35:02 PM »
I do feel you are missing the point slightly. The object of the exercise was to learn how to go from a 2D plan to a 3D plug and to do it without spending lots of time and expense. I posted my findings as to help other people who are new to the hobby get a taste of what's involved in making a plug. It would be silly making a mould in such a small scale and I never planned to. The mould will come once a full scale plug is built using the lessons learnt while making this practice piece.
wartsilaone
« Reply #5 on: May 01, 2011, 07:56:13 AM »
I know this seems like a pointless exercise but at the end of the day I had made a model boat and I enjoyed doing it. Isn't that what this forum is all about?
richald
« Reply #6 on: May 01, 2011, 08:09:04 AM »
Wartsilaone I follow your logic here . . .
I'm just waiting for you to get it hollowed out, and a motor, battery and RC gear fitted!  ;D
Richard
wartsilaone
« Reply #7 on: May 01, 2011, 08:17:53 AM »
Another reason for doing this was that I'm am going to casting small ships like these. Hopefully sell a few.
Ali.
Bryan Young
« Reply #8 on: May 01, 2011, 06:00:50 PM »
So, not to put too fine a point on it....you aren't really making a plug for a large model, but want to make small scale resin miniatures. Right? If so, why didn't you say so in the first place. BY.
wartsilaone
« Reply #9 on: May 01, 2011, 06:14:08 PM »
Bryan. Yes I will be making a proper full size plug for a proper full size boat with all the proper detail but that will be way off in the future and at least now I know how I am going to do it.
Ali.
