Author Topic: Queen Mary 2  (Read 3262 times)
Paularai
Queen Mary 2
« on: May 06, 2011, 08:39:24 am »
Hi
Thought I would post some pictures of progress of construction of QM2 at 1:150 scale, Turning out to be quite a large model!
Pictures of plug construction below.
Hoping to use scale azipod propulsion.
Would be interested to hear from anyone considering building QM2 or has looked at working azipods.
Plug made from hardboard filed with polystyrene.
Last Photo: Revell 1;400 model for scale!
cos918
Re: Queen Mary 2
« Reply #1 on: May 07, 2011, 10:34:36 am »
Hi Paul
Nice build but you going to need a bigger car LOL
Paularai
Re: Queen Mary 2
« Reply #2 on: May 25, 2011, 08:59:56 am »
How good are you at making trailers!
Started on superstucture front which will be moulded as an integral part of the hull mould.
( Full build album )
http://smg.photobucket.com/albums/v226/paularai/
Paularai
Re: Queen Mary 2
« Reply #3 on: June 23, 2011, 09:29:49 am »
With all rain recently had to find some indoors work!
Plug construction for pods, mould will be taken in order to make 4 identical pods. These will be equiped with 20mm inrunner motors with an aircraft prop adaptor connecting motor to prop. The adapter with run through a small o ring to provide some level of protection against water ingress. End plug will be removeable for drainage and maintenance purposes
Plug made from Alloy tube wood and body filler.
Plug half submerged in Playdough in order to take first mould half
Have made some progress with hull plug, as well as having refined shape of hull, I have now added superstucture front, and sides towards the stern which will form superstructure sides rear deck tiering and wind breaks.
Hope to be in a position to take a mould from the plug within next month.
cos918
Re: Queen Mary 2
« Reply #4 on: June 23, 2011, 08:39:30 pm »
Hi Paul
No good a trailers.
QM2 is looking good. Like the molding on the pods
Paularai
Re: Queen Mary 2
« Reply #5 on: June 23, 2011, 09:21:10 pm »
Thanks John, hope my plans for the internals and steering gear work. Obviously as per original, the front pods are fixed and the plan is the rear will have 180 degrees rotation. Like the full size will make all of them interchangeable.
Can you run more than 1sensorless type of brushless motor from 1speed controller?
Paularai
Re: Queen Mary 2
« Reply #6 on: June 25, 2011, 04:56:11 pm »
Some pod moulding progress.
Subsonuc Mike
Re: Queen Mary 2
« Reply #7 on: June 30, 2011, 12:59:18 pm »
can't wait to see this finished
Paularai
Re: Queen Mary 2
« Reply #8 on: July 01, 2011, 05:12:45 pm »
Pod came out of mould, what a relief  :}
3 more to go!
getting ahead of myself!
Test fit motor, just fits.
Some  more hull progress
Wings below bridge added
Page created in 0.116 seconds with 21 queries.
