Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13   Go Down
Author Topic: WIDE-A-WAKE LAUNCH FOR STUART TWIN ENGINE  (Read 99136 times)
Patternmaker
« on: May 31, 2011, 04:12:15 pm »
Keel, Dead Wood, & Stem Scale 2” - 1ft  Length 50.5” Beam 15”
Bernhard
Re: WIDE-A-WAKE LAUNCH FOR STUART TWIN ENGINE
« Reply #1 on: May 31, 2011, 06:14:38 pm »
Great  :-)),,,,,,,cant went to  the nex photos show up..........
Regards Bernhard
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #2 on: May 31, 2011, 06:41:35 pm »
Looks great already!
KBIO
« Reply #3 on: May 31, 2011, 08:34:18 pm »
Good evening!
A very neat and good start. Good wood quality.
Patternmaker
« Reply #4 on: May 31, 2011, 09:24:30 pm »
The timber is Sapele a species of African mahogany, I am fortunate to have contacts in double glazing companies, they give me their discarded mahogany window frames when they replace with UPVC
otherwise they would end up in a skip.
Patternmaker
« Reply #5 on: June 04, 2011, 05:39:46 pm »
Transom, Hog, Apron & Shaft Log
Bernhard
« Reply #6 on: June 05, 2011, 07:01:40 am »
  :-)) :-)) :-))   Thanks...............
south steyne
« Reply #7 on: June 05, 2011, 09:50:37 am »
Hi I have also made a start on this beautiful model, well I have the keel timber and your pics have given me a real boost to my confidence and just looking at the pics I am sure yours will turn out great.
Just wondering what size prop you will use as my plans are to build a model similar size to yours and seems to indicate around 80mm.
Keep up the great work and please more pics would be really appreciated.
Cheers to all
Patternmaker
« Reply #8 on: June 05, 2011, 10:54:56 am »
Hi John,
I have managed to get 4” dia 3 bladed cast prop which I will cut down to 3” balance & sharpen in order to get nearer to the suggested pitch of 8”.
I would suggest that you loft the lines at model size as some of the half breath measurements for the moulds are incorrect.
Good luck with build, I look forward to seeing some pictures of your build, I will be posting pictures of each stage of mine.
Regards Mick
pipercub1772
« Reply #9 on: June 05, 2011, 02:14:38 pm »
hi could you tell us were you got the plans from, its looking a great build and given me inspiration to build or at least attempt one myself keep the pictures coming they look great ,regards Allan
Patternmaker
« Reply #10 on: June 05, 2011, 03:55:15 pm »
Hi Allan, I got the plans from ebay, copied from Model Boat magazine dated February 1972, I don't know when you intend to start building, if you cannot find a set I can send you mine when I have finished with them.
Mick
Patternmaker
« Reply #11 on: June 05, 2011, 04:07:06 pm »
Engine position.
pipercub1772
« Reply #12 on: June 05, 2011, 04:40:29 pm »
Mick, thats very kind of you i will not be starting for a couple of months and i could get it copied and posted back to you ,i have a hemmens max 2 engine and boiler that i have waiting to put  to use and that looks a great project for the winter, is it clinker built hull  or carvell cant wait for more pictures,  kind regards Allan
Patternmaker
« Reply #13 on: June 05, 2011, 07:30:29 pm »
Allan, its a clinker built hull.
Mick
kno3
« Reply #14 on: June 05, 2011, 09:29:47 pm »
I really like the massive wood construction of the keel and other parts!
How long is the boat going to be?
Patternmaker
« Reply #15 on: June 05, 2011, 10:08:27 pm »
kno, Scale is 2" to 1 foot, hull is 50.5 inches long with 15" beam, the keel and stem are 1" sided tapered which would be 6"X 6" on a 25ft hull.
Mick
Patternmaker
« Reply #16 on: June 06, 2011, 06:57:38 pm »
Hull Moulds
pipercub1772
« Reply #17 on: June 06, 2011, 08:20:41 pm »
this is a great build project for anyone to follow keep them pictures coming, now i think the difficult bit the planking regards Allan
Bernhard
« Reply #18 on: June 06, 2011, 08:51:18 pm »
Patternmaker
« Reply #19 on: June 06, 2011, 09:53:39 pm »
Thanks Bernhard.
Patternmaker
« Reply #20 on: June 07, 2011, 11:19:33 am »
Sheerline
A valid comment has been raised about the tumblehole on the transom normally this would start about two thirds from the bow, because of the steep sheerline of Wide A Wake it only starts from station 4, 10” from the stern where the sheerline and parallel line from the keel merge.
I have noticed that most of those built so far have no tumblehome on the Transom, I have followed the plans as I think this looks better.
gondolier88
    • Coniston Regatta
« Reply #21 on: June 07, 2011, 07:33:46 pm »
Hi Mick,
You're right; with the sheerstrake battened out it looks far more balanced.
Are you battening out for the all planks?
Greg
Patternmaker
« Reply #22 on: June 07, 2011, 08:35:22 pm »
Hi Greg,
I will not be battening out all the planks, I am happy with the lines of the hull now the half breaths of the moulds have been corrected, I did consider 14 planks per side but have decided to keep to the original 12
Mick
logoman
« Reply #23 on: June 07, 2011, 10:21:11 pm »
What a great build log, it's like watching the Carpenter.
barryfoote
« Reply #24 on: June 08, 2011, 07:59:26 am »
That is beautiful wood working. A real pleasure to see it. Thanks.. :-)) :-))
Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13   Go Up
Page created in 0.403 seconds with 21 queries.
