Model Boat Mayhem - Forum
Author Topic: Caldercraft Northlight  (Read 612 times)
steamshed
« on: June 05, 2011, 04:37:10 PM »
Hi All
Having built the Northlight and using an electronize motor 543-12 low drain on 6v jelly with 40mm 3 blade prop, it needs full throttle just to move it around, can anyone please suggest a better alternative
PS all the electrics stay cool.
Subculture
    • Dive-in to Model submarines
Re: Caldercraft Northlight
« Reply #1 on: June 05, 2011, 05:20:48 PM »
Might be better with a  prop with a bit more pitch. Have a look at the prop shop range.
steamshed
« Reply #2 on: June 06, 2011, 07:48:13 PM »
Thanks for that Sub
john s 2
« Reply #3 on: June 07, 2011, 09:09:49 PM »
Please check that your Esc is giving full power. Check by connecting motor direct to battery. Possibly you
could increase battery voltage, subject of course to motor and esc limits . John.
Roadrunner
« Reply #4 on: June 07, 2011, 10:35:30 PM »
Good advice...
Remember the electronize range of esc have a 'speed' screw top right i think you should adjust this when the esc is receiving the transmitters signal for full throttle, there is also a 'L-V-H' screw hole which i expect is set to V at present which is 'variable' you may wish to turn this up to H ( high) and see if anything improves with the adjustment of those two settings.
Be sure to follow the instructions that came with the esc as i typed this out by memory of setting up a club member's recently and be careful with the screw adjustments use a watch makers flat head screw driver ( 2mm head i think).
If after all that has failed to do anything worth while, then look at changing the prop to either a larger pitch or smaller prop 35- 38mm as a good starting point, buy plastic ones to start with once you have a good setting then purchase the prop in brass its cheaper in the long run for 'experimenting'.
If none of those do anything.... try upgrading to a 600 size motor as they can still be used with your esc which i'm assuming is a 15amp? if its the 30 or 40amp esc you can go much higher in motor size 800-850's but this may be to much power!
