Model Boat Mayhem - Forum
Author Topic: It Works!!  (Read 2592 times)
MichaelK
It Works!!
« on: June 19, 2011, 06:52:22 AM »
Hi, I,ve just (sucessfully) had my TVR1A engine running on steam.  :} :}
There were a few hickups in getting to this stage, but thanks to members of this forum and members at my local boat club, I have most of them ironed out.
 I'm using a Minature Steam 3 1/2" boiler, at 2 bar pressure.
All I have to do now is finish the boat that it all fits into.  {:-{
Mick
derekwarner_decoy
Re: It Works!!
« Reply #1 on: June 19, 2011, 07:02:31 AM »
Congratulations Mick........I hope my VITON o-rings helped   :D ............Derek
kiwimodeller
Re: It Works!!
« Reply #2 on: June 19, 2011, 11:55:32 AM »
Looking good, dont forget the photos as the boat progresses. Is that a throttle valve you are operating with your right hand and if so where did you get it? Can you tell us about the problems you ran in to, might just save someone else from having to go through the same things. Thanks, Ian.
MichaelK
Re: It Works!!
« Reply #3 on: June 20, 2011, 12:10:52 AM »
Thanks Derek, they did, and I've found a local supplier for all little bits and pieces. (except 5/32" brass tube fittings!)
Ian, The steam regulator came from DRG Tools in the UK. I believe I bought the last one they had in stock, don't know the status now. It appears to have good progressive control over the steam, so the engine can be run at speeds from extremely slow to flat out.
The latest problem I cured was way too much condensation in the system, some times to the stage that on startup, the engine was just about completly hydraulik locked.Cured it by putting a u-bend of tubing down into the back end of the fire box and out again.(A bit like super heating).
This can be seen in the photo.
Hope this helps someone
Mick
kiwimodeller
Re: It Works!!
« Reply #4 on: June 20, 2011, 10:43:26 AM »
Thanks for that Mick, I will do a search for DRG. You can get 5/32 fittings from Geoff at Model Components in Brisbane http://www.modelcomponents.com.au. Cheers, Ian.
MichaelK
Re: It Works!!
« Reply #5 on: June 26, 2011, 05:55:01 AM »
Still a long way to go, but sometimes you have to put it together just to keep the inspiration  going.
kiwimodeller
Re: It Works!!
« Reply #6 on: June 26, 2011, 09:11:38 AM »
Nice lines to the hull, is it your design, plans or a kit? If you are anything like me you will end up spending as much time contemplating it as you do working on it! Keep up the good work. Cheers, Ian.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: It Works!!
« Reply #7 on: June 26, 2011, 09:47:18 PM »
Looks very like a British/German Admiralty Cutter, it's looking really good.
Greg
MichaelK
Re: It Works!!
« Reply #8 on: June 27, 2011, 02:45:33 AM »
Thanks Guys,
The lines are from a "damphinasse", downloadable from the web.
The plans are not quite right, {:-{ as it seems the original, which someone has scanned, has a 3 or 4 mm section missing near the bow. So I redrew them as best I could, Its a good way to learn how to loft the frames off a normal boat plan. O0
The rest is fairley standard plank on frame construction.
Off to the toy shop now to but some paint for the Captains bald head and grey beard. {-)
Mick
MichaelK
Re: It Works!!
« Reply #9 on: November 13, 2011, 01:37:56 AM »
At Last, I've put the boat in the bath for final ballasting etc, and fired up the plant.  ok2
There seems to be plenty of back wash from the prop, and the rudder sends the stern from one side of the bath to the other. :-))
Now it is next weekend to front the "Steam Policeman" :police: at the club for final approval to the boat can have insurance etc.
The photos are taken just after the bath test.
Mick
derekwarner_decoy
Re: It Works!!
« Reply #10 on: November 13, 2011, 01:49:40 AM »
Congratulations Mick.....we can see the Lady S's wet bum in the boat7 snip......... {-) ....keep us posted with more images on her first official voyage  %) ...Derek
Bernhard
Re: It Works!!
« Reply #11 on: November 13, 2011, 09:12:42 AM »
Hi....Nice Launch you have made, :-)),,,And  now to the lake and enjoy....
Bernhard
charles fitton
Re: It Works!!
« Reply #12 on: November 14, 2011, 04:50:53 PM »
Nay chance of a link to the plans?
thanks.
BarryM
Re: It Works!!
« Reply #13 on: November 14, 2011, 07:13:25 PM »
Are you sure its DRG and not RDG?   www.rdgtools.co.uk
Barry M
richald
Re: It Works!!
« Reply #14 on: November 14, 2011, 07:32:57 PM »
Try
http://www.rdgtools.co.uk/acatalog/Models_and_Steam_Fittings.html
about 3/4 the way down the page for the regulator I think....
Richard
MichaelK
Re: It Works!!
« Reply #15 on: November 15, 2011, 06:36:08 AM »
Thanks Derek, Hopefully my darling wife can drive the camera and get lots of photos. ok2
Bernhard, Thank you, and I am sure this little boat will give me lots of pleasure, as I improve it little piece by little piece! O0
Barry, it is RDG tool, (Woops another typo!) {:-{
Charles try http://www.john-tom.com/MyPlans/Steam%20Engines/ModelSteam%20BoatPlans/DampfPinasse/SteamBoatPinasse.pdf
There is lots of interesting stuff on the john-tom website. :-)
Mick
MichaelK
Re: It Works!!
« Reply #16 on: November 20, 2011, 05:05:21 AM »
The Maiden Voyage! :-))
At full steam ahead she looks a bit bow-down, {:-{ at more realistic (and economical) speeds she looks very convincing. ;)
She works, therefore I'm a Happy Chappy! O0 O0 O0
Mick
Bernhard
Re: It Works!!
« Reply #17 on: November 20, 2011, 07:44:12 AM »
OH,, yes.. :-))...thats it
Bernhard
KBIO
Re: It Works!!
« Reply #18 on: November 20, 2011, 07:56:44 AM »
 :-)Good morning!
Lovely Mickael! She looks real on the water and as you say; no need to go full steam ahead as you displace a lot of water for a big volume of steam. {:-{
A few ropes and stuff on the deck will make perfect. :-))
congratulations. ok2
derekwarner_decoy
Re: It Works!!
« Reply #19 on: November 20, 2011, 08:19:13 AM »
Hullo Mick.....  %)......
The vessel sits a level trim at low speed or when still   :-))
So any bow wave produced is relative to the dynamics of the hull and not necessarily related to the power out of the engine  :o
She looks great on our OZ waters @ our temperatures with the steam discharge .......
 >>:-( I am still plodding on with my steam package ........today I sprayed the engine base plate with RED primer ........Derek
nick_75au
Re: It Works!!
« Reply #20 on: November 20, 2011, 09:24:43 AM »
Is that down at Narrabeen lake, I was a member there around 2001-2002, very nice build :-)
Nick
MichaelK
Re: It Works!!
« Reply #21 on: November 21, 2011, 06:21:21 AM »
Thank you Bernhard, Praise indeed!
KBIO, Ropes, bollards, fairleads, maybe a life-ring hanging somewhere, etc, is all part of the plan. Plan "A" is to get her to this stage.
Derek, At realistic speed she looks lovely on the water, no neen to waste steam trying to set a speed record!. But the wave pattern down the side does look pretty. Your plant looks very impressive, are you still putting it into the Murrary Rv Steamer?
Nick, it is at the same venue. It's a sweet little protected spot there isn't it.
Mick :}
Muleears
Re: It Works!!
« Reply #22 on: November 21, 2011, 05:10:28 PM »
Beautiful boat!  What did you use to mount the engine?
MichaelK
Re: It Works!!
« Reply #23 on: November 22, 2011, 08:28:26 AM »
Hi Muleears,
The whole plant (gas tank, boiler, engine, servos, etc) is fixed to a piece of (very old) pine, with cut-outs for the boats ribs, which I can then remove in one piece for cleaning etc. :} The pine is held in place by gravity and sweat! O0
Normally the process is to align everything (propshaft etc)  :-)),but I did it backwards!  {:-{therefore I've had to pack up the motor so it alignes with the propshaft. I also re-drilled the 4 holes in the engine bottom plate to accept 4mm SS bolts and nuts.  That's the backward process! {:-{
I've also taken out the "superheating coil" from the set-up, it made no difference to the overall performance.
Hope this helps
Mick
« Last Edit: November 22, 2011, 08:31:17 AM by MichaelK »
kiwimodeller
Re: It Works!!
« Reply #24 on: November 22, 2011, 09:24:56 AM »
Hi Mick congratulations on both the succesful debut and an informative lot of postings. Two questions occur to me looking at your steam plant. The first is how does the rotary throttle valve perform? Do you get a smooth progressive control? The second question relates to the first. I note you are not running the optional flywheel, will the engine still run slowly without a flywheel? Thanks, Ian
