Hello all
I'm new to this forum and have joined becuse a very helpfull member Alius "Patternmaker" was kind enough to answer my call for help from UTube.
I started making the steam launch miranda some 20 years ago when I was working but failed miserably on the making of the hull.
The engine was made from scrap metal from the plans with exception of the crank that I turned out of one piece, it got up to 2,500 revs on air.
and ran nicely on steam but did not measure it as I was too excited at the time.
I'm now trying to make the hull again with the vast help know available on the internet.
My main failing at this stage(and I’m sure there will be many) is how to plank the hull.
The author of the plans produced an article over 3 months that I have copies of but just says skin it with 15tho ply and then plank it?
I've read plenty but really I learn more from Pictures!!
So as not to make my first post too long :-
Is there any one that has any pictures of the stages of planking.
Just running the planks from front to end is not correct but how do you know where to start?
Top, Bottom, a little of each, and is there a pattern as to when you fit what i think are called "fillets"
Thank you for any help you can give I've posted a picture of my engine in it's very sorry state of "Lofting" for 20 years.
