Pages: [1] 2 3 4   Go Down
Author Topic: Kenny builds the TITANIC  (Read 30902 times)
« on: July 18, 2011, 11:30:50 am »
I have been building this gorgeous ship for the last 6 months.
Re: Kenny builds the TITANIC
« Reply #1 on: July 18, 2011, 11:51:08 am »
There is a lot of information out there on this ship and it is not collated all together. The research took ages and the literature was obtained from all over the world.
There are plenty of very small kits by various manufacturers and all the ships vary in details, so I tried to ensure I had the most accurate version I could make. What I didn't want was the comments at the lake of  "you shouldn't have put that bit there"  or  " are you sure she only had 20 lifeboats".
I decided  (due to age !!)  that she must a reasonable size to make working on her a little easier, so I decided on a scale of the model railway  "N" gauge, which makes her 1:175 and produces a model about five and a half foot long. This also proved an advantage when it came to the assembly of the 'Little people'  ok2
We started with timber structure using the band saw and loads of wood from an old pallet. I have taken hundreds of pictures and won't bore you with all the little details but just show a general route through the construction.
« Reply #2 on: July 18, 2011, 11:56:02 am »
The band saw came into it's own when I cut the 200 or so planks.
« Reply #3 on: July 18, 2011, 12:48:37 pm »
Had a bit of fun with the props shafts as we were in uncharted territory. Thanks to Marks Model bits for the extra long ones.
mersey dave
« Reply #4 on: July 18, 2011, 12:48:47 pm »
Looking good keep us posted on your progress. :-)) :-))
Regards Dave.
« Reply #5 on: July 18, 2011, 12:58:24 pm »
Thank you Dave.  Just sorting out which pictures to transmit. Some were taken which were altered on the final model.
Ken
tony52
« Reply #6 on: July 18, 2011, 01:30:16 pm »
Ken,
Here is photograph I took back in 1998. This model was featured in a newspaper after crashing into the bank on the maiden voyage!
« Reply #7 on: July 18, 2011, 01:44:37 pm »
Thanks for that Tony. Another picture for my records.  :-))
It's not a lucky ship, even to build.   %)             Mine tips over on the water but that's at the end of my story.   :((
On with the photos after lunch
ken
Arrow5
« Reply #8 on: July 18, 2011, 01:51:53 pm »
...aw naw, the butler did it !  Thanks for spoiling a good story ! >>:-(  Be sure to give an autopsy, top heavy due to pallet wood ? {:-{
..well can you land on this?
« Reply #9 on: July 18, 2011, 01:53:45 pm »
                                     Got it in one              {-)
ken
« Reply #10 on: July 18, 2011, 04:37:49 pm »
Proceeding with the build we worked our way upwards.
You will notice the large amount of heavy wood used but have no fear as most of it has been exchanged for plastic.
Arrow5
« Reply #11 on: July 18, 2011, 04:38:21 pm »
Elementary my dear Watson  {-) {-) Foamboard would have been er ..um..paperweight :embarrassed: :D  Did you know you are being used as an example on RCGroups ?
« Reply #12 on: July 18, 2011, 04:42:08 pm »
The prop tubes were covered in and then it was out into the sunlight for a photo call.
« Reply #13 on: July 18, 2011, 04:43:02 pm »
See all that 'orrible' weight going on top   %)
ken
« Reply #14 on: July 18, 2011, 04:47:06 pm »
The funnels had to be hand made so I chose the ever faithful coffee stirrers from MacDonalds.
These were wrapped vertically around oblong formers and glued overnight.
Arrow5
« Reply #15 on: July 18, 2011, 04:49:42 pm »
Ach yer wee man is out of scale
« Reply #16 on: July 18, 2011, 04:52:14 pm »
Wait until you see the picture with my hand on her parts.   {-)
Next we built up the Bridge deck to get an idea of the shape of her. This turned out to be replaced later with a plastic version.  (beginning to loose the weight a bit !)
We also Knocked up the Glass dome for the Grand staircase
« Reply #17 on: July 18, 2011, 05:10:39 pm »
Next we had the problem of the planking.  We tried printing the parallel lines onto a card after pricing various options. This looked very nice when laid on the decks, but proved a bit difficult when glueing parts on top which needed to be firm.
« Reply #18 on: July 18, 2011, 05:12:51 pm »
Talking of scale a little while back, I have place the  'lovers'  on the bow
Arrow5
« Reply #19 on: July 18, 2011, 05:37:46 pm »
Aw you romantic fool {-)
« Reply #20 on: July 18, 2011, 06:03:57 pm »
Thought that might bring a smile.
Next I filled in the gaps and smoothed out the hull ready for priming.
« Reply #21 on: July 18, 2011, 06:13:06 pm »
The plating of Titanic is well documented so I was able to follow the contours with accuracy.  The hull bottom was clinker built and curving around the bilges it progressed to sheet iron plates laid flat. The joins were plated over with strips on alternate rows.
I used a very thin plastic to cover the whole ship and then laid strips alternately along the sides.  This was done twice to correct the errors and was a steep learning curve.  (and expensive!)     The last picture is the improved version.
Enter the builder's finger.   O0
« Reply #22 on: July 18, 2011, 06:21:44 pm »
A start was made on the inside by fitting the battery box.  C Deck was then glued in as, no more large parts were to go underneath.
We then dry fitted some of the pieces and took a few snaps.   ok2
« Reply #23 on: July 18, 2011, 06:23:34 pm »
The builder alongside to show the size she's growing to.  %)
« Reply #24 on: July 18, 2011, 06:29:32 pm »
The next part was the funnels.
These were covered in one piece of thin plastic which was riveted  (punched with a nail) with over 500 rivet marks in a pattern of squares.
Pages: [1] 2 3 4   Go Up
Page created in 0.101 seconds with 21 queries.
