Author Topic: Battery Pack  (Read 2476 times)
Peewee
    • Paddleducks
Battery Pack
« on: September 12, 2011, 03:05:30 pm »
Hi All,
I am after a battery pack thatwill sit under the WTC in the free flooding area.  does anyone know where i might be able to obtain one.
cheers
Still sane? who knows who cares?
hollowhornbear
Re: Battery Pack
« Reply #1 on: September 12, 2011, 03:15:25 pm »
that's a bit like asking "how long is a piece of string"
more info is required like space available, make and type of sub, etc. then i'm sure someone may have the answer you require.
Peewee
    • Paddleducks
Re: Battery Pack
« Reply #2 on: September 12, 2011, 03:33:26 pm »
its an OTW S class with an OTW dive unit.  ideally i am after  a 12V 4-6 AH that will fit along the keel.
hope this helps
andyn
Re: Battery Pack
« Reply #3 on: September 12, 2011, 04:38:32 pm »
Pm sent :-))
Subculture
    • Dive-in to Model submarines
Re: Battery Pack
« Reply #4 on: September 14, 2011, 04:14:53 pm »
You could go for a stick of 10 sub-c size cells running for and aft along the keel. That would be closer to the 4Ah capacity, and I would say a larger pack would be more suitable for a boat this size.
A stick of D size cells would be required if you want higher capacity whilst remaining with Ni-MH technology. I would think you will have room in that big S-class, but I could be mistaken.
Another solution would be to look into A123 lithium batteries. These offer higher capacity to size, four cells in series would give you 12.8 volts. They are a little more tricky to source in larger capacities. Suitable chargers are also a little thinner on the ground, although readily available. A123 batteries will cost more upfront, but have a much longer lifespan than competing battery technologies, so in the long term, should work out the cheapest option.
ajg141
Re: Battery Pack
« Reply #5 on: September 14, 2011, 04:47:39 pm »
Chris Cloke at Sheerline does a 12v pack for his Trafalgar. I think the latest version is 12v 3700mah but you could ask him. I've used one for years and it works extremely well.
sheerlinesubs@btinternet.com
Andrew
Peewee
    • Paddleducks
Re: Battery Pack
« Reply #6 on: September 14, 2011, 07:37:00 pm »
thank you all.  its much appreciated
Page created in 0.094 seconds with 22 queries.
