Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18]   Go Down
Author Topic: OTW Vanguard help  (Read 109997 times)
thegrimreaper
Re: OTW Vanguard help
« Reply #425 on: May 24, 2012, 02:40:33 pm »
Windy day at New Brighton when this was taken plus I think the boat was slightly out of balance was a good test for my new video camera though
http://youtu.be/veCxiF8Vrdc
hope you like
    Mark.
Don't lie, thieve, cheat or steal. The Government do not like the competition.
Subculture
    • Dive-in to Model submarines
« Reply #426 on: May 24, 2012, 03:56:50 pm »
Good stuff- heels over a lot though when the wind catches it.
You could try adding more foam and lead in the keel to increase stability.
Another thing that might work is to try a trick passed onto me By Ron Perrott. Use hollow tanks with as small hole at the top, and a couple of larger holes at the bottom. These should be fitted above the waterline, and they act as bouyancy chambers and help stability by providing a righting moment without incurring a big weight penalty. Because the flood holes are small the tanks take time to flood.
If you want a practical example of this, get an old plastic milk bottle, drill a small hole in the top, say 3mm, and a couple of larger holes in the bottom, try pushing it under water, and you'll see it bobs straight back up again, but place a weight on it, and you'll see it slowly fills and sinks.
Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18]   Go Up
Page created in 0.098 seconds with 21 queries.
