Hello everybody - could you advise me on a best possible solvent for cleaning a syringe from epoxy catalyst?
The other syringe that I use for epoxy resin is easily cleaned with acetone and works just fine after several uses.
The one used for catalyst remains sticky and basically I can't now use it any longer after several times. I tried acetone, and cellulose thinner, tried ethanol; and isopropanol. l Ethyl alcohol seemed to work better than acetone perhaps I just started using it too late.
Although they aren't expensive I don't want to throw away a syringe after every 3-4 uses...
What's your experience?
Am I right to assume that you are using syringes to dispense the two part epoxy into its mixing container prior to mixing (at the correct quantities/ratios)?
If I am wrong, ignore the rest of this post.
If my assumption is correct, here is an alternative which I use for the 5 to 1 mix needed for the West System epoxy:
I bought a cheap set of micro weighing scales that weigh in increments of 1 hundredth of a gram. Cost less than £10 delivered.
All I do is place my mixing container on the scales, set them to zero, and pour the main mix in. Note the weight. Reset the scales to zero. Add the catalyst (in this case the main weight divided by 5) and pour that carefully in until I am one drop of catalyst away from the necessary weight.
The big advantages of this method of dispensing are:
1 It is very accurate, critical for small mixes to ensure the correct ratio.
2 It is not messy as there are no syringes to clean up afterwards.
3 It is surprisingly quick to do after a few mixes.
4 It saves cost in terms of buying syringes (or other dispensers that rely upon volume measurements) which are not needed this way.
Food for thought perhaps?
Craig
