It looks like I'll be supervising the 27MHz and 40MHz frequency 'peg' board. I've suggested much as Colin and others have said:
1. 30 mins slots, after which the pegs should be returned. If nobody else wants to use said peg then the user can retain it for the next 30 min slot and so on. There should be a clock with the correct time by the peg board. This is the one the timings go off, not someones watch, mobile phone or whatever to avoid any argument. Slot times are on the hour or half hour.
2. There should be a sheet on the peg board with time slots across the top, pegs down the side. Anyone using a peg MUST write their boat name/own name or both in the slot. This will help retrieve missing and non returned pegs, and help keep track of users and make sure everyone has a fair chance to sail.
3. Nobody should expect to be able to 'reserve' a specific frequency for the whole day or weekend.
4. There will probably be periods set aside for specific displays of certain craft such as:
Warships/Naval
Sail power
Lifeboats/rescue craft
Straight running
These periods should run on both days. There perhaps should be an hour at least between these specific displays for 'free' sailing.
I agree it would be a good idea to make better use of the bottom end of the lake. A scale course would be a great addition, especially for the more vulnerable boats. This I assume could still be used when the 'specific displays' are taking place (except straight running unless you're brave), priority for frequencies should go to those wanting to take part in the display though.
The system should pretty much run itself so long as everyone agrees to whatever the final 'rules' are. It's getting much less of a problem these days with 2.4ghz systems getting cheaper and cheaper. You now know what to put on your Christmas list if you've not already got one,
Dave.
