Model Boat Mayhem - Forum
Pages: 1 [2] 3   Go Down
Author Topic: King Midas Tug  (Read 6449 times)
Dreadstar
Re: King Midas Tug
« Reply #35 on: December 18, 2011, 04:19:14 PM »
A little bit more painting done today,with the tugs deck now looking distinctly grubby,not planned by the way. Decks have been painted,where appropriate,(Gnarlock Green),and the insides of the bulwarks also done,along with the banding on the funnel(freehand).
« Last Edit: December 18, 2011, 04:21:40 PM by Dreadstar »
Dreadstar
Re: King Midas Tug
« Reply #36 on: December 18, 2011, 11:36:12 PM »
Wheelhouse now painted.
Dreadstar
Re: King Midas Tug
« Reply #37 on: December 19, 2011, 11:48:32 PM »
No new pictures today,as all I was doing was refixing the lead ballast in the bottom of the tug. I left her sitting in the bath for 4 hours today,just to be sure that there are no leaks,and guess what.......there are none..brill. :-))  The only problem with this little tug is,that it's no lightweight,it's actually heavier than the Cyclops,by at least a 1lb. This has really surprised me,considering just how light this model is to start off with. I can't tell you the final all-up weight,as I don't own a set of scales,though I'd guestimate around 8-10lbs possibly. I'll try to get some more painting done to her upper works tomorrow,before I tackle the main superstructure. O0
Dreadstar
Re: King Midas Tug
« Reply #38 on: December 22, 2011, 04:38:18 PM »
I've more or less finished the major painting of her now,and because I'm impatient,I took her down to the pond for a quick test. Now I knew that I'd get water into the hull,as the two halfs were,as was the rest of the boat,only held together with Whitetac. ( I didn't really have any opportunity to take pics,as the water was a little on the choppy side.)
   I couldn't get the tug up to even half throttle as,the water was coming up to the underside of the bow flange,and the stern was beginning to dig-in. Maneuvering was really not all that bad considering the thickness of the rudder in section. Once I've glued this little boat together properly,she'll make a nice wee adition to my growing fleet.
  I repainted the wheelhouse roof black,because the dark blue roof just looked too out of place.
Dreadstar
Re: King Midas Tug
« Reply #39 on: December 23, 2011, 05:44:35 PM »
I've tried joining the upper and lower halfs of the hull together with a bead of silicon sealer,held together with the bumper strip which clamps the two halfs together. I'm not sure if this will work or not,as I've had to repaint the hull,due to the masking tape pulling off parts of the paint. I'm not sure why this happened,as I'd prepped the hull before painting,by washing it down and rubbing the surface with 800 grade w/d.  :embarrassed:  It's a pity,as the weather is far better for test sailing today too,with the pond being very calm. Ah well,maybe another day then,and I can get some video made of her.
 It won't be long now before I can start gluing all the components together in their final positions.
Dreadstar
Re: King Midas Tug
« Reply #40 on: December 26, 2011, 06:32:28 PM »
More or less finished now.
Re: King Midas Tug
« Reply #41 on: December 26, 2011, 08:57:05 PM »
... not bad!  %)
     Get some crew figures on there sir!
"This is my firm opinion, but what do I know?!"   -  http://www.modelboatmayhem.co.uk/
Dreadstar
Re: King Midas Tug
« Reply #42 on: December 26, 2011, 11:27:46 PM »
Don't worry Martin,the deck crew are still to come. At the moment the only crew members on board her are the skipper and helmsman in the wheelhouse. :-))
Dreadstar
Re: King Midas Tug
« Reply #43 on: December 27, 2011, 05:16:26 PM »
Finally managed to get down to the pond today for her first real test sail. I don't know what I did to my camera,but it seems to be out of focus,unfortunately,I didn't have my glasses on at the time or I might have been able to sort it out. You'll note that I keep losing the tug in this vid,that's because I'm using a stick controller rather than my usual pistol grip one. This model is using a T4U 2.4GHz controller,and the throttle that I'm using is just 2 clicks up from neutral. She's running on a 3-blade 25mm prop with a 4.8V 3600mAh battery. I did give her a couple of full throttle bursts,but I was afraid that I'd get water inside the boat,as the stern joint went under the surface on full power. However,I needn't have worried,as when I finally brought her in after half an hour,the inside of the boat was completely dry. :-))
http://youtu.be/Go0yvEyoqJ0
ZZ56
Re: King Midas Tug
« Reply #44 on: December 28, 2011, 09:04:45 AM »
Very nice and compact build, Dreadstar.  She sure moves out when you 'put the hammer down'.   O0
Re: King Midas Tug
« Reply #45 on: December 28, 2011, 11:54:16 AM »
Excellent job!  :-))
 Who did you get to do the naming ceremony?
hama
Re: King Midas Tug
« Reply #46 on: December 28, 2011, 12:56:13 PM »
Great little tug, well done! She looks very stable.
Hama
Dreadstar
Re: King Midas Tug
« Reply #47 on: December 28, 2011, 02:36:46 PM »
I'm afraid Martin that this was just a test sail,she's yet to be named. Any suggestions greatfully recieved,(within reason that is).  Speed wise people,she was operating on barely 20% throttle,remember,that it's a 380 motor that's in her and not the more common 385. For a small tug,she's got a lot of spare power,even with just a 25mm prop. Originally,I'd been going to fit a 40mm prop,but even just trying that in the bath told me that she'd be overpowered,so I downsized to a 30mm one before realising that I'd need to drop down to a 25mm one if I wanted to be able to attempt to control her at low speeds. :embarrassed:
  I've still to finish off the main superstructure as you can see,it's missing the doors and handrails still,plus the steps up from the deck to the hook level. I also need to lighten her a bit as she's sitting rather low in the water at the moment,but these are picky little points that can be done at any time. ok2
  Although this little kit is pretty straight forward,I found it harder to do for some reason or other ,than my previous builds,especially trying to fit the gubbins inside her,and finding that a lot of glues just won't work. The servo is still just mounted in place with a large blob of Whitetac,which seems to work surprisingly well. On the whole, I must admit that I'm quite proud of my wee tug,as it's turned out better than I'd hoped it would. At the end of the day,it's my painting that tends to let my builds down,but I'm still learning. :-))
Tug---Kenny
Re: King Midas Tug
« Reply #48 on: December 28, 2011, 03:03:24 PM »
How about  "Lady Star"   (or the name of a loved one )    :}
Dreadstar
Re: King Midas Tug
« Reply #49 on: December 28, 2011, 11:48:17 PM »
Thinking about this a little more,and I was thinking,shouldn't tugs have a more masculine name? Now since this is a King Midas,what about Auric Rex,or even The Golden Touch? Other ideas that I had included Diomedes;Aenus;Viator;Speedy(because of the 380 in her);Legend; or even The Mighty Atom?
Dreadstar
Re: King Midas Tug
« Reply #50 on: December 30, 2011, 04:43:22 PM »
I finally got round to fitting the steps from the rear deck to the tow deck;from the upper deck to the wheelhouse roof and the ladders to the rear of the mainmast. :-))
I've also added a new radar dome above the scanner.
« Last Edit: December 30, 2011, 04:47:34 PM by Dreadstar »
murphy1570
Re: King Midas Tug
« Reply #51 on: December 31, 2011, 01:03:37 AM »
Hello Dreadstar
I have been following your post with great interest and the King Midas is looking great, but I see you say you  had some problems gluing the parts togther how did you overcome this as I said the model is looking great, would MEK PAK orPlastic Weld work on it? what glue did you find that worked best/
Thanks all the best John.
Dreadstar
Re: King Midas Tug
« Reply #52 on: December 31, 2011, 06:30:05 AM »
Mek Pak & Plastiweld both work brilliantly on this model,however,the problem comes when you are trying to glue non-plastic materials to this plastic. You must treat the surface of the plastic that you are gluing  onto with some w/d 180 grit if you want even Araldite to stick non-plastic materials to it. Superglue also works well,but not on for instance balsa. Keep away from the poundland type epoxy's,as they will not stick to this plastic at all  :((
 Most of this model has been glued together with Plastiweld,which I highly recommend for this type of plasti. I hope this answers your question John.
Dreadstar
Re: King Midas Tug
« Reply #53 on: December 31, 2011, 11:36:11 AM »
Right then lads,I went out this morning to re-film her test run,this time with some full speed runs. She's a very stable boat,probably because of the amount of lead that's in her,as you can see,she's got a fair wee turn of speed. :-)) A vid and a few pics.
http://youtu.be/HLMioZrKIYs
« Last Edit: December 31, 2011, 11:39:38 AM by Dreadstar »
Dreadstar
Re: King Midas Tug
« Reply #54 on: January 02, 2012, 12:07:24 AM »
I did my lone sailor bit today for about 30 mins,then had to give up,as I could no longer feel my fingertips. It was a ruddy cold wind today,not particularly strong,but cold. Having said that,I had fun just blasting the Midas around the pond at whatever speed I chose. The water was a little choppy,but nothing to write home about,even driving the boat at full chat into the wind,with water splashing over the foredeck,no water got into the boat. For a second level seal ,other than just the extended sides of the main hull opening,there is a liberal smearing of that old favourite.....Vaseline.
   It was however just too cold to do any filming today,though I did snap off a few pics. Just how did I manage to get to the pond today I hear you ask. Well it was quite simple,SWMBO and the kids went up to see her mum this afternoon,and I took the oportunity to nip down to the park whilst they were there.
 A few pics from today,trying to show the only two deck crew that i have just now.
Dreadstar
Re: King Midas Tug
« Reply #55 on: January 02, 2012, 01:59:42 PM »
I'm getting ready to head down to the pond again today,to give her another run. I've removed some of the lead from the bow,which has lifted the bow up to the waterline now,whereas before,she was running too low at the bow. I'm going to see if this improves her running attitude any,and see if the bow stays out of the water a bit more,rather than riding as low as it had been. Providing that it's not too cold,I should manage to get some video made of her today.
Dreadstar
Re: King Midas Tug
« Reply #56 on: January 02, 2012, 04:07:01 PM »
Well,I'm back and you'll be able to tell from the video,that it was a touch on the chilly side. I've tried to include a bit of a comentary in this vid,but it wasn't easy.  Anyway,here's todays installment,quite possibly my longest vid to date as well.
http://youtu.be/K6KcBMLERjE
Dreadstar
Re: King Midas Tug
« Reply #57 on: January 04, 2012, 04:04:39 PM »
Well,that's all the major work done on her now,I've just received and fitted the bow protector. Now I know that the way I've tied it on is not the correct way,but without using glue,I couldn't see another way of keeping the bumper hard up against the flange. It's just secured using multiple half-hitches and no extra string.  I'm just awaiting the vinyl lettering now,and she'll be more or less complete. :-))
« Last Edit: January 04, 2012, 04:14:12 PM by Dreadstar »
Dreadstar
Re: King Midas Tug
« Reply #58 on: January 05, 2012, 05:28:29 PM »
I went down to the club this afternoon,expecting at the very least,one other soul to be sailing their boat. Guess what,yet again I was the only member out on the pond. A few of the others weren't venturing out because of the large amount of broken branches in the pond,after Tuesday's big blow,which toppled four large trees in the park,one of them right next to the pond.
http://youtu.be/YqEBZxhiWZ4
Re: King Midas Tug
« Reply #59 on: January 05, 2012, 06:42:25 PM »
Dreadstar
Re: King Midas Tug
« Reply #60 on: January 05, 2012, 07:36:01 PM »
Martin,didn't you know that insanity is hereditary...........you get it from your children.
Re: King Midas Tug
« Reply #61 on: January 05, 2012, 07:56:15 PM »
Dreadstar
Re: King Midas Tug
« Reply #62 on: January 07, 2012, 11:59:56 AM »
I managed to find another few figures to use as crew,the first one is only mid way through being painted. Name added to funnel.
« Last Edit: January 07, 2012, 12:24:51 PM by Dreadstar »
Dreadstar
Re: King Midas Tug
« Reply #63 on: January 09, 2012, 03:10:01 PM »
Since yesterday was not a good one for sailing,I took the opportunity today of nipping down to the park,to test out the Auric Rex under tow conditions. Since I don't have access to a barge,I had to settle for using my heaviest boat,in this case my 1/24th RTTL. I don't know what I was expecting,but she performed far better than I could have imagined,considering how small her prop is. I took a video,as I do,but I hadn't realised just how long it actually was,until I started to upload it. There was at times some pretty stong cross winds to contend with,but I think I did not too bad for someone who knows sod all about towing.
  Some pics and the vid.
http://youtu.be/tLHSEh0FHSM
Dreadstar
Re: King Midas Tug
« Reply #64 on: January 15, 2012, 04:12:08 PM »
I was looking forward to giving the Auric a run around the pond today,so imagine my surprise to find it frozen over. Now not being one of those people who give up easily,I decided to smash some of the ice up so that I could at the very least get some pleasure out of the day.
 What I hadn't bargained on was the ice being a 1/4" thick,not that that stopped me overly much,but it did mean that by the time I brought the tug back in,I'd lost a fair amount of paint off the bows. I'm thinking that it's time to get some of my brass angle section out,and glue it to the prow of the boat,just like all my other boats have. Hopefully,this'll help protect the bows from further damage.
A couple of pics amidst the ice floes.
Dreadstar
Re: King Midas Tug
« Reply #65 on: January 15, 2012, 04:42:53 PM »
Found and fitted a short length of brass angle to the bow of the tug,I'm just waiting for the Araldite to set.The damaged paintwork has also been touched up.
Dreadstar
Re: King Midas Tug
« Reply #66 on: January 22, 2012, 05:36:02 PM »
A few pics and a short vid from today.
http://youtu.be/jBjxNgSvLEA
Re: King Midas Tug
« Reply #67 on: January 22, 2012, 06:26:43 PM »
I want a posed photo with you and the tug for photo of the month please.... a preferably a pretty lady and the tug!
Welsh Wizard
Re: King Midas Tug
« Reply #68 on: January 22, 2012, 06:37:49 PM »
Now you want Jam on it Martin LOL
Dreadstar
Re: King Midas Tug
« Reply #69 on: January 23, 2012, 05:24:36 AM »
I've no problem if you'd like to use a pic for photo of the month,but you don't want a pic of my ugly mug spoiling things Martin. :embarrassed:
Pages: 1 [2] 3   Go Up
