Hi Neil,
I would like to know how to produce a silk screen but I'm not pushing incase its a trade secret... I asked my Mum ( An x Head Teacher ) her methods would be great in a School environment but not neat enough for production. Please don't tell her i said that as the wrath of a Headie i can live without (Headie - Glasgow for Head teacher... amongst other terms non repeatable ...)
Kim
hi Kim,
It's no trade secret at all, and although I can tell you the technique by which they are made, I don't make them myself, only the method of how they are made.However I will say that when professionally made the silk is so tight on the frame it can almost be used as a drum.
Firstly you draw out on quality draughting paper with a black ink pen, (I used to use Rotring pens and their ink, but not having used them in a very long time, they are now kaput)the inpressions of what you eventually want to produce on timber or plastic. The ink has to be dense black for the same reason that you need it to be for brass etching, as it is basically the same process.
Taking it along to a silk screen producer, they will photograpg the print that you have drawn and by photo transfer will transfer a negative onto your sceen, which will already have been stretched over a frame. This is to ensure that there is no distortion of the print.
The black lines of the print will now be in negative form and will allow ink to be pressed through it, whilst the clear of the paper will have been blacked/blanked off as impregnable.
The screen is then placed over the timber and a small amount of ink is placed at one end of the screen........with a rubber squeegie, the ink is squeezed along the screen with the ink passing through only where the lined of the print once were, thus giving a perfect impression of your drawing onto the timber or plastic.
the ink is usually water soluable and washed off after a number run, so as not to block the holes in the silk screen. I can't remember from memory because the ones I had made for the Anne Letitia Russell were over 17 years ago, but I think they were about 120 denier rating, but I do remember they cost me even then over £250 for the 4 in various sizes that I had made.............but whether the originals have long been scrapped I honestly don't know, but they are, if treated with respect, good hard workers. lol
