you would not believe how long it has taken today, just to mask up the decks of three models ready for spraying the antislip areas to the decks, and the deck surrounds..........just unbeleivable, but now it's done, some colour on the models will encourage me to get on with the topside cabins and detailing.
I sprayed the antislip to the parts of the deck needed with a textured paint which dries with a gritty type look, and although not the colour I need for a classic lifeboat, the texture isn't far from what I need, so, not being a true purist, I'll settle for it, with a colour wash later to the lighter grey that I want to match the kick boards.
And in the order, the photos are:
Masking up.
the inner parts of the front cabins of the H F Bailey and the Mary Stanford posed a little dilemma as I had no combings to stick the tape too......so I coated the inner walls with masking tape and then shoved an old rag into the well to cover the floors.....hope it works, lol
And before I sprayed the textured paint which would almost certainly bung up the small 0.5mm holes that I had drilled to take the pins for the kick boards I inserted some longer brass rod into the start and finish holes to locate the kick boards once the paint had dried.
And then using the textured paint and here is a picture of the textured paint can I use for the none slip deck coatings I did a little shaking and then got down to the serious stuff, and added my first colour.
OOOOHHH.can feel the sap rising, lol
With the end result.
Just have to leave it for 24 hours now for the paint to set solid.
