Hullo & thanks George ....when you say......."Air vessels on toy steam engines are not required they may look the part but don't work" ....is it that we cannot accurately measure or monitor pulsation & any dampening effect at our low pressures of say......3.5 Bar with our model pressure gauge systems? as in theory they [any fixed gas accumulator] must have a dampening effect.............
Our member Bernhard........builder of open hull steam vessels has installed a form of accumulator in a number of his steam vessels.........possibly he may offer comment here
regards Derek
Hi Derek
If you can't accurately measure the dampening effect in such low pressures an air vessel it's not required.
Our friend Bernard as far as I can see builds superb model boats but I can't see any sign of engine and boiler builds.
One thing I am not and that is a model boat builder but have built many engines and boilers of all sizes including high pressure Flash steam plants and I assure you that air vessels on the delivery side of our small model pumps are not required and it didn't work on the larger engine that I posted a pic off.
Keith,
I must say that those little TVR engines are very well made and priced, being C.N.C. made , Graham can churn them out very quickly.
I had to do a repair on one once for a friend, the flanges on the manifold to the cylinder were leaking steam and he had messed about with the timing.
The timing was sorted quickly but my heart was in my mouth with the brass screws into the Ali cylinder block which by memory was 10 ba.
I was terrified that I would either drop the screw or strip the thread into the cylinder head, otherwise great little engines.
Ian,
One of the biggest problem in scratch building is buying small quantities of brass and steel, I have found that suppliers in Glasgow are not keen on cutting , say a 6" length of 1" round bright steel but quite willing to sell a 3 m length.
This is why I save up and put an order into Blackgates for stock material and collect when I visit Rochdale.
When I was in business and moving amongst engineering works I was able to pic up scrap lengths of materials , but alas no more,
George.
