Ive just seen topic about building a home made ESC and thought about something i built a while back for a large scale RC truck Ive been working on.
you can make your own servos out of pretty much whatever DC motor you want using a old servos and a small home built circuit called a "H bridge"
This circuit takes the signal from the original servo motors power supply and use it to control a circuit that can drive a much much more powerfull motor. the motors position is achieved by linking the motors shaft to the pointometer on the old servo this can be done ether by adding a bar on the large servos horn to the small one or you can do what i did and connect to the rear of the motors shaft directly. now your large high powered motor will follow your transmitter stick wherever you tell it to go, return to neutral when your stick does and will resist forces applied to it just like a standard servo even when in neutral position, it will behave exactly as a standard servo does just with a hell of a lot more pull to it. my home made servo has so much power it could cut your finger off, you have to be very carefull lol. there is however another use for this circuit, a esc of sort!
If everything is wired up but you do not link the pointometer from the old servo up but set it to zero instead you now have a speed controller! you will get progressive control over the motors speed as you advance the stick on your transmitter and because you have no sensing attached the motor can be run continuasly and when you return to neutral the motor will just stop where it is, reverse your stick and your motor will reverse in the same controlled mannor
heres pics of my controller, its spaced out and you can reduce the size a lot, adding heatsinks would also allow you to run much higher amps. i forget what this is rated at but it drives my motor under load with only a bit of warmth comming from the transistors. i did not use the exact same components as listed in the diagram i used better and more powerfull transistors for the switching. i replaced Tip120 and Tip125 with Tip142 and Tip147 The N2222's, the capacitor and the resistors were all left as is printed in the diagram .
heres some pics for you.
top view of controller circuit
my large servo motor with old servo acting as sensor
underside or controller
the transistors I used on this board are more powerfull than in the diagram
The circuit diagram for you to look at
