The weather here in scotland has been on the cold side, so struggled to get much done with glues and epoxies etc. Ive set up a form of heating in the garage and have managed to do the framework for the deck ive already cut. Much like the hull supports many little pieces to be cut and glued together.
I have taken pictures, but there isnt a great deal to see, i have still been plodding away on it most days, just seems im floating about in different sections doing little bits. The hull below water just needs to be finnished with paint, bow thruster grills and to glue on the fake anodes and sonars. Ive done a fair bit on the hull above water, all holes have been drilled and cut including hawsers, the only hole to do is anchor.Much like the bilge keel, ive found the trim that was formerly the deck height a bit more difficult than anticipated, it is so thin in all directions but they are done, just the bow one to do.
It would be very easy to just paint the former deck line, also easy to paint the detailing for water escapes and tank in/outflows, but ive done it the hard way, in my mind im hoping it will give greater depth and realism to the model.
The deck water escapes and tank flows, i drilled out and cut to there shape, the tank flows are in line with the deck supports i put on earlier and i managed to drill and cut to a decent depth. Because these naturally lie close to the waterline, i prethought about how to tackle this as i dont want water coming in. The holes are sealed from the inside with resin, resin is also applied from the outside. ( havent tested yet)
The deck run offs, i will be sealing with clear plastic. Id love to have it all real, just cant afford water in about the electrics i just dont have the space for sealed tanks and water collectors.
Ill post pictures again at some point, just not a great deal to show that is different.
