Model Boat Mayhem - Forum
Author Topic: My new Victoria arrived BROKEN, what do I do?  (Read 3279 times)
Muleears
« on: January 04, 2012, 09:45:13 PM »
My new Krick ($$$) Victoria arrived today from MiniSteam with a crack in the main deck!  It appears to have happened in shipping as the box was somewhat crushed.  My question is what should I do?  I could repair it and it would be barely noticeable, BUT, should I?  Or should I get on the phone with MiniSteam and see if they will do anything.  The package was left at my door while no one was home, so no one saw the damage before delivery.
Here are a few pics:
There are two cracks, the one above the level of the pen is clean through.  The one below is just a crack about 2" long.
Is this something I should just fix myself or should I make an issue out of it?  I am NOT a master model maker, a flaw like this will probably blend in with all the other flaws when I am done.  So, what do I do?
Muleears
Re: My new Victoria arrived BROKEN, what do I do?
« Reply #1 on: January 04, 2012, 09:51:31 PM »
After posting I realized it may be hard to tell what is a crack and what is supposed to be there.  Below I have highlighted the cracks in the deck.
« Last Edit: January 05, 2012, 07:55:36 AM by Martin - admin. »
Welsh Wizard
« Reply #2 on: January 04, 2012, 10:17:25 PM »
Contact them and tell them you want a replacement I would not stand for it myself
dodgy geezer
« Reply #3 on: January 04, 2012, 10:19:22 PM »
With any kit or service of any kind, if you have any issues at all, you should make these known to the provider. Whatever the issue, they are the ones who will need to deal with it, and I am sure they would much rather find out from you directly than from reading your comments on a modelling forum.
« Reply #4 on: January 04, 2012, 10:33:40 PM »
I had a Deans kit delivered recently and the same thing happened, the box had been crushed in transit and the hull badly damaged but it was not at all obvious when I took the delivery, it had clearly been pushed back into shape before being given to me. It looked OK on the outside and you can hardly open up and inventory a well wrapped kit on your doorstep before signing for it. I contacted Deans and Ron sent me a new hull by return of post with no quibbles. Full marks for that. He told me that transit damage is a common problem but it is almost impossible to get the carrier to accept liability.
So yes, get back to Ministeam and explain the situation. It is incumbent upon them to remedy the problem and take it up with the carrier if they want to do so.
« Reply #5 on: January 04, 2012, 10:47:48 PM »
Ministeams problem not yours, get in touch with them they are legally responsible to sell undamaged goods.
Muleears
« Reply #6 on: January 04, 2012, 11:08:08 PM »
I have sent a polite email to them outlining the situation.  We'll see what they do.
snowwolflair
« Reply #7 on: January 04, 2012, 11:42:59 PM »
Anything broken I find when unpacking I stop and photograph it.  The less unwrapped the better.
I send them to the suplier both to get a replacement but also to help them make a claim against the carrier.
The worst I ever had was a laser power supply, not an insubstantial bit of metal, reduced to a quarter of its thickness. and full of airfield mud.
The carrier (DHL) said a lorry had run over it, but without a complaint from a recipient their policy is  to delivered it.
The funny thing was that Customs had subsequently inspected it wrapped it, mud and all, and charged duty on it.
I got it replaced FOC.  After some trouble customs waived the duty on the second unit when I threatend to send a photo of what they had done to an appropriate government bureaucracy hating tabloid newspaper.
« Last Edit: January 04, 2012, 11:50:13 PM by snowwolflair »
dodgy geezer
« Reply #8 on: January 05, 2012, 01:18:06 AM »
They need to know what is happening to their packages - if there is a poor service they may want to change their carrier. It does their reputation no good for people to receive damaged goods...
The long Build
« Reply #9 on: January 05, 2012, 02:11:01 AM »
That the best bit of damaged kit I have seen..  %%
« Last Edit: January 05, 2012, 08:08:47 AM by Martin (admin) »
Guy Bagley
« Reply #10 on: January 05, 2012, 09:23:50 AM »
come on david, with your talents thats a quick fix !!!
hopeitfloats
« Reply #11 on: January 05, 2012, 10:12:54 AM »
way down here it would have to be fixed. too expensive to get a replacement. bit of tin bashing, tube of glue, some silicon sealer and its good as new. ok2
Muleears
« Reply #12 on: January 05, 2012, 11:20:56 AM »
I'm afraid I may have to end up just fixing the Victoria and living with the crack.  It would probably cost another $50 to ship the kit back to MiniSteam.  I may have to decide if its worth another $50 to have a uncracked deck. It would make me very happy to just receive another deck in the mail.  That seems to me to be the simplest and cheapest solution.
« Reply #13 on: January 05, 2012, 11:48:54 AM »
That's what Deans did for me, just replaced the damaged hull in armour plated packaging!
Muleears
« Reply #14 on: January 06, 2012, 12:49:00 AM »
Well, its been a day and no response from MiniSteam...
I want to do something with the boat but I don't dare till this is resolved.  I guess I'll wait another day or so.
pettyofficernick
« Reply #15 on: January 06, 2012, 02:15:58 AM »
If you have to repair your deck, any evidence will be hidden by the planking, which completely covers the subdeck.Here is a link to a good set of photo's of a Victoria build that I found when I got mine. :-)) :-)) :-))
http://www.flickr.com/photos/90322523@N00/sets/72157605148425113/
derekwarner_decoy
« Reply #16 on: January 06, 2012, 05:38:56 AM »
Muleears ....I agree with pettyofficernick regarding the fix.....which would be technically and mechanically sound with two reinforcing strips glued under the decking.....
You could always pen a detailed costing note to Ministeam...quoting ...the return costs + new deck cost + return shipping costs back to you.......scenario.......
Make an estimate of each ....then suggest that you would be happy with a Ministeam voucher for say 50% of the actual costs for redemption at their store.......just a thought  :o......Derek
Muleears
« Reply #17 on: January 06, 2012, 09:28:41 AM »
MiniSteam replied last night at about 830.  Apparently they are trying to get me a new deck.  I would be satisfied with that.   :-))
« Reply #18 on: January 06, 2012, 11:27:58 AM »
Probably one of the worst times of the year to persue any claims/complaints. No doubt they are now getting their 2012 heads on after the festivities, it's only the 6th of a new year. At least they have responded with what looks to be an agreeable solution.
   Now to start actioning a claim with RM for lack of delivery. >:-o
   Regards   Ian.
Muleears
« Reply #19 on: January 06, 2012, 12:08:12 PM »
Great pics, thanks Nick.  These have given me some ideas.  It is my goal to have the Victoria finished by my annual vacation in mid July.  We stay on a lake in central New York for a week, perfect opportunity to learn to steam!
pettyofficernick
« Reply #20 on: January 06, 2012, 05:08:16 PM »
You are most welcome. I will post some photos of mine when I resume the build, It has been idle on the slipway through lack of funding. I see you come from Virginia, I have been watching a most interesting TV show about a Virginia coal mine on TV, thoroughly enjoyable!
Nick. :-)) :-)) :-))
CF-FZG
« Reply #21 on: January 06, 2012, 05:26:26 PM »
What's it got to do with RM ok2
Muleears
« Reply #22 on: January 07, 2012, 12:37:39 AM »
Well, I got a pleasant call from Suzann at MiniSteam tonite.  They seem to be diligently working on my problem.  They are trying to get me a new deck from Krick and are opening a case with UPS.   UPS may want the entire package back though, kit included.  So I still can't do anything with it!   I must say, so far MiniSteam is getting a  :-))
CF-FZG
« Reply #23 on: January 07, 2012, 01:21:31 AM »
Looking like a good result so far :-))
Mark.
« Reply #24 on: January 07, 2012, 12:01:14 PM »
 Nothing as far as the Ministeam claim is concerned. Just hope my own to Royal Mail goes as smoothly, - - - but I know it won't.
   Regards   Ian.
Muleears
« Reply #25 on: January 11, 2012, 04:43:05 PM »
UPS is picking up the box and the broken deck tomorrow to return to MiniSteam.  At least its progress.  I hope I get the new deck soon, I'd like to start on the boat!
Muleears
« Reply #26 on: January 25, 2012, 07:12:03 PM »
I just got this interesting letter from MiniSteam:   >>:-(
"Hello, Calvin,
UPS is not going to honor any claim on this shipment.
I pulled a new one off the shelf and looked inside. It has a board in it also where the punch-out pieces are already to begin to come out.  I don't think it will survive a shipment and with the cost to ship we are reluctant to ship this item also and face the same consequences of broken pieces.
We will gladly refund all your money. "
In my reply I pointed out that the pieces falling out of the sheets was not the problem, it was the cracked deck.  I went on to ask if they are going to stop selling the Victoria and where else could I get one.   This answer confounds me.  Aren't they in business to sell kits???  Where else can I get a Krick Victoria?
john s 2
« Reply #27 on: January 25, 2012, 07:57:09 PM »
Yes shipping can cause problems. But so much depends on how an item is packed. If say a deck was packed between two boards then all would be ok. Sadly the cost would be high. It does seem that often damage can and will occur. Possibly you could contact the makers directly? John.
justboatonic
« Reply #28 on: January 25, 2012, 08:42:56 PM »
"Hello, Calvin,
Why wont UPS 'honour' the claim? Was it sent to you uninsured?
Anyway, I guess the supplier thinks damage will be made to any kit they send and perhaps dont want to insure due to extra cost (insurance can more than double the initial courier costs).
But, imho, for such a small bit of damage as shown, I wouldnt have been bothered providing there had been no other damage. Others may disagree, all Im saying is for such small damage, i wouldnt bother asking for a new kit or replacement.
grasshopper
    • A1 Hobbies Ltd.
« Reply #29 on: January 25, 2012, 09:14:44 PM »
I am thinking along the same lines as 'Justboatonic' - from the photograph it's really quite a simple fix, if it's only a subdeck and will be planked then there's less of an issue.
The supplier has been willing to refund you but if getting another one from elsewhere is such a problem stick with the one in your possession and repair.
I must be mad - I've opened my own hobby and model shop,  http://shop.a1hobbiesltd.com/
CF-FZG
« Reply #30 on: January 25, 2012, 09:52:28 PM »
There lies the problem,
Mark.
grasshopper
    • A1 Hobbies Ltd.
« Reply #31 on: January 25, 2012, 10:02:11 PM »
The customer is the one in the driving seat at the moment. Cancel the claim, decline collection and keep the slightly damaged goods - as long as the customer is happy-ish then everyone will fall into line.
« Reply #32 on: January 25, 2012, 10:07:21 PM »
Was the kit returned? That is the question!
If it wasn't then a repair is the obvious way forward. If it was then a refund seems to be the only option and then look for an alternative kit.
A replacement deck would have been the best solution. When my Deans hull was damaged, Deans sent me a replacement which was very well protected and not at all heavy.
CF-FZG
« Reply #33 on: January 25, 2012, 10:27:42 PM »
It was due for collection two weeks ago, and to answer
In my experience - UPS won't make a decision on the claim without everything in their posession.
Mark.
Muleears
« Reply #34 on: January 26, 2012, 12:55:44 AM »
The problem is, UPS required the return of the kit and the box, so now I have neither.  My point of view was that I had paid for a complete undamaged kit and that was what I expected.  As it stands now they have offered a refund which I am inclined to accept, IF it includes a refund of the original shipping cost.  But now where do I get a Krick Victoria?  Had I known from the start that ending up with no kit was a possibility I would have kept the one I had, but unfortunately that is now not an option.
