Author Topic: Springer Tugs  (Read 1321023 times)
Re: Springer Tugs
« Reply #1800 on: June 12, 2014, 07:27:38 pm »
A couple of 555 direct drive with the rest of your
set up.
Speed is not an option with springers unless
you go brush less/lipo and maniac speeds.
They tend to nose dive with too much power.
Slow revs and plenty of torque with twin Korts
will make a fine model.
tugnut
Re: Springer Tugs
« Reply #1801 on: June 12, 2014, 07:43:38 pm »
This one is single screw and tows and pushes well
KillerDave
Re: Springer Tugs
« Reply #1802 on: June 13, 2014, 07:27:52 pm »
Thanks for the replies guys!
I think I should K.I.S.S it.....
Tugnut, Wow, that looks great pushing that barge!!!
What drive have you got there?
What would you suggest I put in for a single KORT, 150% Springer???
tugnut
Re: Springer Tugs
« Reply #1803 on: June 13, 2014, 08:39:42 pm »
Hi Dave, its a 555 on 12v 40mm prop and rudder.it would be better with a nozle.
this is the other one with the same set up
KillerDave
Re: Springer Tugs
« Reply #1804 on: June 13, 2014, 09:58:56 pm »
That's awesome Tugnut! Thanks for the info....
What's the pump for? fire nozzle??
So, if I was to build a 150% Springer, maybe a pair of gearboxed 600's with 50-60mm props and Korts would bey strong but not too fast???
tugnut
Re: Springer Tugs
« Reply #1805 on: June 14, 2014, 04:03:21 pm »
That would be one powerfule springer O0 ,yes the other one had fire moitors
KillerDave
Re: Springer Tugs
« Reply #1806 on: June 14, 2014, 04:17:31 pm »
MONITORS! That's the word I was looking for! Lol... Hmmm....???? I might have a new idea just handed to me!  :-))
Powerful? Would it be too fast? should I reign it in a little???
Z750Jay
Re: Springer Tugs
« Reply #1807 on: June 24, 2014, 11:11:53 am »
Morning all
The current springer was the first boat I built so is carrying all the newbie mistakes I made, the most important being not thinking forward to changing things later. The upper superstructure is very small so I am stuck with fitting everything in the hull (all the electronics, motor and two lead batteries). Gets warm in there plus is a pain to work on due to my big hands not having any space.
I am thinking of a major refit. New superstucture, bigger deck opening kort nossel and different batteries(lighter)
Z750Jay
Re: Springer Tugs
« Reply #1808 on: July 09, 2014, 12:59:41 pm »
Scrub around my last. Managed to kill the springer this weekend  :((
Went to pick it up to do some maint after her sterling service at the MM and DF65 regatta this weekend as a rescue and mark recovery boat and the darn deck gave way dropping her from about 4 foot onto a concrete floor. All the electronics, batteries etc were ok but the hull is now kindle wood. Scared the cr@p out of the land sharks (my cats )as well .
Currently designing a super springeresk thing. Roughly springer shaped but moving away from the hydrodynamic properties of a brick. Only 16" long but 11" wide it will have two fixed kort nozzles with 60mm props. I am going to name it the Clarkson as it's all about POWWWWWEEEEEEER.
Props, motor and battery with a hull around them.
Calimero
    • Calimero's RC shed
Re: Springer Tugs
« Reply #1809 on: July 09, 2014, 04:32:36 pm »
Too bad for your springer.  <:(
I get your Clarkson thing. I also have a regulation-size springer (but with a brushless motor and a 45mm prop which helps tow 350kg ships). But right now I'm designing a slightly bigger one (around 600m; 1.25x the reg size).
My first springer was just a side project while working on my Odin tug. But I really like my springer ! Funny little thing and with the right prop she's able to tow quite well. And run time is around 4h.
Anyway, I'm going with two 50mm props in steerable korts with brushless motors. Not as wild a prop/size ratio as your project but I'm positive she'll tow well. We have CNC cutting machines at my club's workshop. Still need a quick introduction as how to run them. Then go !
johnhelmer
Re: Springer Tugs
« Reply #1810 on: August 14, 2014, 07:35:29 pm »
http://youtu.be/6vOAjgp20s8
-Spruffer "Vital Spark"
Arrow5
Re: Springer Tugs
« Reply #1811 on: August 14, 2014, 08:47:43 pm »
Aye John, no bad, no bad at all at all.   Ye`ll be needin` a crew, nae doubt they will be hardy souls o` the sea, aye.
..well can you land on this?
Bob K
  • Bob K
Re: Springer Tugs
« Reply #1812 on: August 16, 2014, 08:58:28 am »
My newly acquired Springer Tug "Misha" following change of motor and complete rewire.
Single shaft with Kort. 555 motor. 2 x 6V 4.5Ah batteries in series. Continuous sailing duration at least 2.5 hours.
Arrow5
Re: Springer Tugs
« Reply #1814 on: August 25, 2014, 01:52:58 pm »
    Great looking pusher Bob, now a rake of barges ? %)
chrislang
Re: Springer Tugs
« Reply #1815 on: October 24, 2014, 09:18:47 am »
Reading this after a long break I relate to Z750 Jay's experience with dropping his Springer, as mine had a simular experience after prolonged use by two of my Grandsons. The result was a holed and badly delaminated ply hull, having looked at the possible repairs, sheathing with fiberglass etc was quite costly, so I eventually found that 'Models by Design' produced a complete Springer hull for only £20. Having bought this I was able to transfer all the components over and she is now somewhat lighter and fully functioning again as in the pic.
'Models by Design' were great to deal with and only a couple of weeks in producing the hull I can't recommend them enough.
Cheers Chris
Z750Jay
Re: Springer Tugs
« Reply #1816 on: December 19, 2014, 03:20:07 pm »
 Not a bad price of £50 for the complete kit.
Currently got a Bantum Canal tug as a stand in for the springer. It's tiny - only 14" long but has all the stuff from the springer in it. Also handles like one with lots of submarining at speed.
One of its good points is that it makes the springer hull look roomy in comparison!
Paxton
Re: Springer Tugs
« Reply #1817 on: March 29, 2015, 10:56:05 am »
This, I think, is the biggest Springer tug I have ever seen. ;)
Arrow5
Re: Springer Tugs
« Reply #1818 on: March 29, 2015, 11:51:05 am »
 :-))   Hope somebody builds a scale model of this one...it`ll send the rivet counters mad. Imagine the pond-side arguments, "it IS a Springer" >>:-( .   "Nah , nothing like it " <*<  etc etc.   Take this picture with you if you do build one. {-)
Re: Springer Tugs
« Reply #1819 on: March 29, 2015, 02:12:41 pm »
           O0        {-)
Re: Springer Tugs
« Reply #1820 on: March 29, 2015, 02:32:57 pm »
Come on boys we can do better than that {-) {-) {-)
Even one for Duncan %%
Arrow5
Re: Springer Tugs
« Reply #1821 on: April 03, 2015, 11:34:43 am »
Oh oh, might need a repaint soon.    Don't forget the Springeren submarine in the Aalborg Maritime Museum in Denmark.
Re: Springer Tugs
« Reply #1822 on: April 03, 2015, 12:06:12 pm »
well they are known to 'submarine at speed'   %)
Arrow5
Re: Springer Tugs
« Reply #1823 on: April 06, 2015, 10:19:01 am »
Further to Ned`s post about the various ships called Springer I Googled the Rhine one and found details. It is an 85m long hopper barge powered by two 450hp diesel Schottel drives. Carries 1500 cu.m. , aprox. 3,135 tons.  It is named after a shoal in the North Sea.
bill stafford
Re: Springer Tugs
« Reply #1824 on: May 16, 2015, 02:40:11 am »
hi guys,
can any-one tell me the size of the little tug on page 31, maid of the mist 2?
I think it is approx. 5M loa ,but i dont know , it is very hard to tell from the photos
it seems small at that size
I am interested in it,as a simple tug ,dont know at what size yet,could be very small , or bigger,approx. 500mm,but its a bit hard to visit from Australia, to find out .
its simple line will lend to a quick built tug
regards and thanks bill S
Pages: 1 ... 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75   Go Up
Page created in 0.147 seconds with 21 queries.
