Pages: 1 2 3 [4]   Go Down
Author Topic: trawler plan  (Read 25281 times)
Re: trawler plan
« Reply #75 on: April 24, 2012, 08:29:57 pm »
 as arney   says ill be back /...........Larry..
But when Larry?
LarryW
Re: trawler plan
« Reply #76 on: June 14, 2012, 04:42:18 pm »
 Hi All ,
       Back on working on north sea trawler , put on test tank for trim test and built rudder and fitted prop shaft  , from MMB IS SHAFTS ARE FIRST CLASS
       looking now for colour  of the hull should be and other paint work can only find black and white pictures,........Larry..
never pass a skip
Re: trawler plan
« Reply #77 on: June 14, 2012, 07:48:00 pm »
LarryW
Re: trawler plan
« Reply #78 on: June 14, 2012, 07:56:19 pm »
Hello Dave ,
               Thank you for reply and picture , it looks pretty close it will give a prompt ....Larry...
never pass a skip
Re: trawler plan
« Reply #79 on: June 14, 2012, 10:03:35 pm »
http://www.hullmodelboatgroup.co.uk/picture.php?/2386/search/791
That model on the Hull site seems the same colour?
It's hard to tell true colours on my monitor though.
LarryW
Re: trawler plan
« Reply #80 on: June 21, 2012, 08:18:17 pm »
Hi All,
 A bit more progress on trawler, bulwarks lined and braced , spray deck fitted and stern cover deck fitted , motor and rudder link finished'
 next move are the deck hatches and winches when i can find the info any help out there?.........Larry...
never pass a skip
LarryW
Re: trawler plan
« Reply #81 on: June 22, 2012, 08:33:16 pm »
Hi ,
  To yorkie , as you can see back on trawler now seeking winch and deck gear and a better deck lay out found your profile most useful....
     don't suppose you have a deck plan  cheers  Larry...
never pass a skip
Re: trawler plan
« Reply #82 on: June 22, 2012, 09:55:32 pm »
LarryW
Re: trawler plan
« Reply #83 on: June 23, 2012, 09:12:32 am »
 Thank you Dave for info will contact trawler man ,.........Larry.....
never pass a skip
LarryW
Re: trawler plan
« Reply #84 on: July 09, 2012, 02:53:52 pm »
 Hi All ,
         A bit more work on trawler ,  deck hatches and winches , cover deck and life boats sorted first winch i made was at wrong scale do to print error ,
  must do better , looking at drawing i am using is nothing like the real Kingston peridot crew and bridge deck slope back on the real one but on the drawing it is strait .,
 done to much now to rectify so it is now just a trawler,  also a lot of f/g hull work to get it right bad moulding , and does not match the drawing no wonder it was in rummage sale.
  so onwards and upwards  :-))  Larry....
never pass a skip
LarryW
Re: trawler plan
« Reply #85 on: July 24, 2012, 08:20:41 pm »
hello  ,
       Starting the paint job now weather is better,......Larry... :-)) :-)) :-))
never pass a skip
Re: trawler plan
« Reply #86 on: July 24, 2012, 08:30:23 pm »
really nice deck gear Larry - it looks well used
LarryW
Re: trawler plan
« Reply #87 on: July 24, 2012, 08:34:59 pm »
    Thank you Dave,
                               using acrylic paint as a trial ,     pond land purchase will have matt spray to bind it Larry....
never pass a skip
Pages: 1 2 3 [4]   Go Up
