Hi everyone, there has been a long discussion on here in another thread by Oldiron (John) that showed when he did a lot of testing that in fact the Huco was actually the worst. A single Huco will only give you alignment in one plane, you will actually always need two if you don't want it to bind, there is a connector available for just that fix. In johns testing the Dumas dog bone was the best of the ones he tested. This has been a bit of a mission for me for some time as I work in the auto business & am very familiar with drive lines, U/J's & C/V joints. It is obvious to me that we are sadly lacking in driveline technology when it comes to our model boat hobby. Walk into any good hobby store & have a look @ the sheer variety of drive systems for model cars of all types, the mind boggles. Because of the restricted space we sometimes work with in our models we need a single type C/V joint in different sizes to fit into many different configurations & power settings. I have been giving it a lot of thought & am at present trying to develop such a joint, I have made three prototypes of which two worked in a half a--s ed way one I ran up to 2000 rpm but had some vibration problems. It drives @ angles of 15 to 20 degrees without any problems.To make it accurate enough to eliminate vibration I require a milling machine as I can't drill the bearing slots for the ball bearings accurate enough & also embedding the balls in the inner hub must be exactly the same distance from the centre for all the ball bearings. As you can see I have solved most of the technical problems, now it is the cost of a good milling machine that is the biggest problem. I am working on that with the boss, with very little success up to now." cant you do it on that new fangled lathe you just bought 6 months ago' is a familiar reply. I will keep you posted on progress, sorry no pictures yet, if I get it right I will probably patent it & put it into production. From once the dwawings are done it could be CNC machined in bulk @ a reasonable price I think, then I hope you will all want to buy one or two, LOL. Mick B.
