Model Boat Mayhem - Forum
Pages: [1] 2 3   Go Down
Author Topic: Detailing "The Rat" ( H.M.A.S. Ararat )  (Read 4709 times)
brianB6
« on: January 18, 2012, 09:40:18 AM »
It's probably about time I started my own topic instead of using Gelns and Dickies.  %%
I have been building H.M.A.S. Ararat "The Rat" an Armidale class Patrol boat for more than 15 months, using Steve Batcheldors fibreglass hull.  The reason for Ararat is that she is the only Boat named after a town in the State of Victoria where I live.
I enjoy doing the detail parts working mostly in brass and perspex.   Yes, they are heavier than styrene but my styrene parts either come apart or the paint comes off.  <:(
The latest parts I have been working on are the 25 mm. gun (see Glens build of an Armidale) and the rear steps.
The diagonal mesh was from Northyard in N.Z. but I am not sure if they still have it.
Although it is about the right dimensions I fear it may clog up when painted.
The bolts will go through the transom so that it can be removed for painting the hull.   I much prefer to paint as much of the boat as possible at the same time but with the details painted separately.
Re: Detailing "The Rat" ( H.M.A.S. Ararat )
« Reply #1 on: January 18, 2012, 11:27:55 AM »
Very nice Brian. I take it that your boat is 1:50 scale.  :-))
brianB6
« Reply #2 on: January 20, 2012, 12:30:27 PM »
Hi Dickie.
Yes, 1:50 to go with my 1:48 Vosper Mk. 3 Corvette and Cervia.
I have done some more turning on the drill to make up some of the anchor handeling details.
They all need finishing off.
« Reply #3 on: January 20, 2012, 01:13:45 PM »
Hi Brian - How do you do that on a drill? I ask because I thought I would have to have a lathe.
A pm would do if you don't want to interrupt your build log.
Thanks Dave
brianB6
« Reply #4 on: January 20, 2012, 11:45:53 PM »
Happy to show the world.  :embarrassed:
The Engineers on this site will probably be horrified at using a drill but I am not trying to make a steam engine.  {-)
I can usually get to within about 0.05 mm. of the right dia. and length.
I have a 13 mm. Makita hammer drill with reverse but no speed control unfortunatly.
Just held in a 4" vice on the bench.
Light cuts only as the drill bearings are not meant for side pressure although the hammer drill bearings are probably better than a plain drill.
For turning I use a series of files from 150 mm. down to needle files and wet and dry paper.
I also use a jewellers saw or junior hacksaw to cut narrow slots and 'square' corners.
The files need to be cleaned with a fine wire brush to get rid of the swarf that clings to them.
Most of the material I turn is brass rod but I have used aluminium and a little steel.
The reverse is really useful as files cut differently in each direction.
Only have the minimum work sticking out of the chuck and try to finish that part before moving the rod out for the next cuts. (As per Glens gun barrel shown below)
brianB6
« Reply #5 on: January 20, 2012, 11:55:04 PM »
Some more turning.   The Anchor and Port and Stbd. stern winches.
The photos really show the faults.  :embarrassed:
Just remember they are less than 10 mm. high. <*<
RaaArtyGunner
« Reply #6 on: January 20, 2012, 11:56:28 PM »
Brian,
Thank you.  :-)) :-))
Any more photos.
Bunnings have a larger 2 speed Makita Hammer drill with reverse, and not overly priced.
However the older ones are be sturdier having been built in Japan.
My variable speed with reverse, 10mm with hammer, is still going strong, bought in late 1970's, back then it cost twice as much as the current bigger Hammer drill.
brianB6
« Reply #7 on: January 21, 2012, 12:24:57 AM »
"Your wish is my command"  %%
The supports for the gun platform and the almost finished gun.   Most of the bits are still loose so may not be properly aligned.
SWMBO wants 'more' cupboards so it may be a few days before I can get back to the boat.  <:(
« Reply #8 on: January 21, 2012, 12:50:36 AM »
Coming on well Brian, makes mine look a little sad.
Brian do you know the width of the superstructure ladders for my 1:72 scale ?
brianB6
« Reply #9 on: January 21, 2012, 05:18:50 AM »
Hi Dickie
Not quite sure.   There are two widths:-
P & S up to Bonnet vents appear to be 425 mm. or 450 mm. ccs. on the handrails. (say 6 mm. at 1/72nd.)
The rest:- Stbd gun platform, Stbd. funnel (2 off, one above the other from bridge deck) Port from rear deck to bridge deck work out to 350 mm. to 375 mm. ccs. on the handrails.  (say 5 mm. at 1/72nd.)
Approx 320 mm. between treads.  (say 4.2 mm. at 1/72nd.)
Handrails (Side rails) about 25 mm. dia. and treads 20 mm.
Maybe Glen can measure them?
« Reply #10 on: January 21, 2012, 05:52:02 AM »
Thanks Bri, that will help a lot.
« Reply #11 on: January 21, 2012, 04:16:14 PM »
Ok Brian - Thanks a lot for the turning info - I can rig something up
I have plenty of spare drills etc  O0
bobk
« Reply #12 on: January 21, 2012, 05:08:09 PM »
Thank you for that Brian.  What a great idea.  I was just thinking about how to create a couple of small fittings.
I have a spare hammer drill and a vice, but no lathe.  I could now do them in brass rather than fabricate in ABS.   :-))
brianB6
« Reply #13 on: January 24, 2012, 08:45:20 AM »
I have not turned every part.   The Trim tab hydraulics are brass tubes since they appear to be almost the right size.  %%
Non of the bits are fully assembled yet so they might show as slightly out of place.  {:-{
« Reply #14 on: January 24, 2012, 08:56:21 AM »
Very nice Brian but could you do that in 1:72 scale ?  :}
Could not do it on mine as it would be to heavy.
brianB6
« Reply #15 on: January 24, 2012, 09:27:03 PM »
Yes, weight has always been a problem with this hull.
That's one of the reasons I used tube and keep any brass sections as thin as possible.
In hindsight, it would have been nice to build in a larger scale. 1:32 perhaps.
Getting to painting time and seeing how "the Rat" performs with a full load.  O0
brianB6
« Reply #16 on: January 30, 2012, 08:14:14 AM »
A few more small parts.
Towing post which will be used to hold the removable section of the rear deck in place.
Searchlight brackets and P & S light surrounds.   I cannot think og the right name.  <:(
The first of 12 Bollards.  Only 11 more to go. %%
Glenedge
« Reply #17 on: January 30, 2012, 08:28:02 AM »
Hi brian
Carpenters Box springs to mind for the side lights!!!!
Glen
brianB6
« Reply #18 on: February 07, 2012, 01:50:27 AM »
Maybe the left hand photo should have been posted under "Name the Part"  %%
What are they? Divers boots  ;D
The right hand photo shows them soldered onto their deck mounting plates.
Yes, Bollards  O0
And NO, I am not going to make any more, even for myself! after getting rid of the cramp in my finger from holding the soldering iron so steady.  <:(
They have to be so accurate to look right and even now I can see the imperfections.
Maybe I should have bought Steve's moulded ones, but I had to give it a try.  {:-{
RaaArtyGunner
« Reply #19 on: February 07, 2012, 02:44:25 AM »
Brian,
Wouldn't worry about it.
Unless the full sized ones are cast, then imperfections will be present in the real thing.
Reckon it adds realism to the model.
derekwarner_decoy
« Reply #20 on: February 07, 2012, 05:03:32 AM »
brianB6........do you have any acquaintances with [small] sand blasting or grit blasting equipment? ...it does an excellent job & turns fabricated soldered components into look like cast items......& a great key for your grey paint
opps....  %) there is no grey in the colour chart..........Derek
« Last Edit: February 07, 2012, 05:08:14 AM by derekwarner_decoy »
brianB6
« Reply #21 on: February 07, 2012, 06:03:33 AM »
The full size bollards are fabricated so cast ones would be wrong.
Plenty of grey, but perhaps it does not matter if the paint comes off. It does on the full size boats!
I use a tooth brush and neat Cream cleanser to get the worst of the flux off.
Photo of Armidale bollard.
Does anyone have a better photo of the Navigation lights?   They appear to be painted black and do not show up very well.
derekwarner_decoy
« Reply #22 on: February 07, 2012, 06:21:44 AM »
1. citric acid removes flux
2. P&S navigation lights on all RAN vessels have the 90 degree included angle back & side plates as flat black
Glenedge
« Reply #23 on: February 07, 2012, 07:57:45 AM »
Hi brian
 As Derek says the mount for the light is painted flat black at the back, base and the bit against the bridgewing. The lights are moulded black and are made by Aquasignal if you want to get some more details on them.
Glen
Peter Fitness
« Reply #24 on: February 07, 2012, 09:32:21 PM »
Lovely work, Brian, and great attention to detail :-))
Peter.
I'm the boss in our house, my wife said I could be.
brianB6
« Reply #25 on: February 08, 2012, 01:34:45 AM »
Many thanks.  O0
I am  not saying where all the mistakes are but the area around the nav. lights has changed 3 times in the past week and I am still not happy.  <:(
Trooper63
« Reply #26 on: February 08, 2012, 04:32:00 AM »
Brian, very envious over here.  I've always dreamed of getting a small lathe, but you have shown it is possible with less expensive options.
brianB6
« Reply #27 on: February 08, 2012, 09:17:52 AM »
I keep regreting that I sold my old lathe.  Not very big and very old but it did what I wanted.
I am never likley to build a steam engine so size is not so important.
I would not mind a small combo mill / Lathe like the Titan 125 if I could ever justify it $859
125 swing, 180 bc.
The drill will have to last for a bit though.
I also use my Makita sander mounted on its side, clamped to the bench, for a lot of shaping.   It's surprising how accurate one can get with a bit of practice.
sjbatche
« Reply #28 on: February 09, 2012, 08:04:29 AM »
Hi Brian
Great work on your build, it is really starting to take shape.
I have only just found the thread after not being on the net for a while after my move to Canberra.
You asked for a photo of the nav lights a couple of days ago. Not sure if you have found one so attched is one that I have.
Keep up the great work.
Steve
« Reply #29 on: February 09, 2012, 08:20:42 AM »
January you revealed the Makita drill turning method
February you reveal the Makita sander shaping method
I just can't wait for the March edition Brian  :-)) ;D
I'll have to buy some Makita shares too  :D
« Reply #30 on: February 09, 2012, 09:56:08 AM »
Topic renamed. :-)
"This is my firm opinion, but what do I know?!"   -  http://www.modelboatmayhem.co.uk/
brianB6
« Reply #31 on: February 09, 2012, 09:37:00 PM »
Happy about that Martin.
I did wonder if Mayhemers would get the inference.
I don't have that many tools that I use in the "wrong" way.   Says he with a band aid on his fingure from sticking a craft knife in it.  <:(
« Reply #32 on: February 09, 2012, 09:52:22 PM »
Been there, done that,,, got the season tick at casualty!   >:-o
« Reply #33 on: February 10, 2012, 02:10:05 PM »
Ha - so funny. I hadn't realised Martin really had renamed the topic.
I thought he was just having a little joke re the Makita tools  O0 {-)
Ha I'm wetting myself here.
brianB6
« Reply #34 on: February 14, 2012, 09:44:38 AM »
I have 'bitten the bullet' and have started painting at last.
Just some undercoat on the hull so far that has revealed some very small pin holes and work that's needed around the prop shafts that have now been filled.
I am going to try using epoxy enamel, as used for metal work.   It is one of the few paints that come in small containers and flat and satin finish. It does take 24 hours to go hard so there will be a lot of watching paint dry. {-)
In the meantime I am trying to work out how to build the davits.   Thanks for all the pics. Glen.
Pages: [1] 2 3   Go Up
