Model Boat Mayhem - Forum
Pages: 1 2 [3]   Go Down
Author Topic: pt-109 build  (Read 3697 times)
bluebird
Re: pt-109 build
« Reply #70 on: February 27, 2012, 09:04:41 PM »
hi there Mike
your build is looking really good - there are a couple more things for you to do the mast and bits and pieces  and judging by the way you have done this it looks like you are really enjoying this building - if you like this style of model, sort of semi-scale have you had a look on Myhobbiesstores plans section because there are loads and loads of this type of build.
I am not sure what you are doing about your speed controllers and things like that but if you fancy a bit electronic kit bashing (for speed controllers) ACTion do their speed controllers in kit form - they are slightly cheaper than the ready made unit - the instructions are very easy to follow and you just require a decent soldering iron and solder to put the kits together - not many pieces in them, and each electronic component is described and clearly shown where it fits in the circuit board.  Food for thought and it just adds that little extra touch to your model, when you know you have done some of the electronics yourself.
aye
john
MikeA
Re: pt-109 build
« Reply #71 on: February 29, 2012, 01:46:18 AM »
hi there Mike
aye
john
thanks John i am enjoying this build but then i enjoy all my builds  ;) its whats its about it isnt it. I had a scan through that website and there were some plans id like to have a go. Ive been told by swmbo to make a canal boat, a rosie and jim one to be precise. Ill see about that.
As far as the esc is concerned im skint now. I use in all my boats except ONE car esc's. They do the job fine, one is this:
http://www.walkera-helicopters.com/shop/apex-electronic-speed-controller-apex-square-forward-reverse-p-6986.html
and the other:
http://www.toysonics.com/hpi-340-en-1-esc-w-reverse.html
I paid ten each for them on ebay and they're doing fine. I was tempted to buy the cheap blue esc's from china but didnt chance it so i bought second hand decent car ones instead, theyve never let me down yet and even been partially submerged!
 Until i get a better esc ill use the Apex Square for now. I would like to buy from action but im afraid i cant afford his stuff {:-{
MikeA
Re: pt-109 build
« Reply #72 on: February 29, 2012, 02:26:13 AM »
Heres an update. Ive done the painting and well its Ok, its not great simply because im no good at it. It doesnt help that i hate painting with a passion either in fact i get swmbo to do the hard stuff on my builds!
Anyway here it is
I have to say ive not had this much trouble painting my boats before. In fact the image you see above you is the SECOND attempt, the first attempt was so shameful i didnt want to post it! When the original coat dried one half of the boat was glossy and the other half was matt. I recall changing brushess half way through painting (dunno why) and presumed it was clean, it looked clean anyway. I think it had some grease on it or something but whatever it was it made a right mess. In order to correct the glossy ness i repainted it once it was dry with a clean paintbrush, seemed to work but it was different shade to the original paint and ended up being blotchy, baring in mind its the same tin!! Dont think i mixed it enough
I went out this morning bought 2 new tins of paint. i mixed them both togeather in a jar using a motor with a bit of rod connected to the end and whisked it thoroughly. Using  a clean brush again i repainted the boat. The final coat seems even and unblotchy if not a little thick in some places.
Ive also made the mast, which atm you cant seem cos its drying. Another thing the flag pole at the back also doubles as the antenna tube for the 2.4ghz wire.  Its actually from a mechincal pencil which i stripped down to get out the central ptfe tube and part of the mechanism which connects on the end. I can take the tube off any time because the mechanism bit its fixed to the boat, and the tube pushes in it perfectly.
I have the guns to make yet and some other little fittings so nearly there. Dare say it wil be on the water friday :-))
MikeA
Re: pt-109 build
« Reply #73 on: March 03, 2012, 04:10:17 AM »
well it wasn't on the water Friday lol still working on it, pushing it a bit there i think %%
Firstly Ive sorted out the appallingly bad bad job to a standard which isn't perfect but satisfactory. Ideally the best coating was the first one but ruined it by changing to a dirty brush half way through. Ohwell live and learn  :embarrassed: I rubbed down the abortion of a job on the hull and re coated it getting out the lumps and streaks doing what i rarely do taking my time!!
OK heres the mast, brass rods soldered togeather with a bit of pen tubing on the top. The plans show a round baked bean tin shape at the top i can only presume is a light. So a light it is:
the mast is removable for transport, albeit not particularly high but brings the height down just a few inches to avoid breaking. The legs push into tubes drilled and glued into the roof, i sourced the tube from blue birds suggestion lolly pop sticks which funnily enough i had saved some few months back when it had occurred to me they would be useful for something :-))
They proved a snug but solid fit onto the diameter brass i was using and proved ideal.
Next up was the flag pole/antenna tube:
simply from a mechanical pencil, I actually buy them 5 for a pound just for this purpose. The parts of the mechanical pencils push togeather a fit into all kinds of ways, on a couple of boats i have i use them for 2mm prop tubes! Anyway that pulls out for transportation purposes too. Even though i have discovered its generally not necessary to have the antenna of 2.4 ghz RXTX to be elevated out of the boat i do just for good measure to make sure the reception is well above the water.
50cal Browning AA turrets:
I cant tell you how much i toiled with these things. I wanted a close to scale appearance as i could manage and being small it was very tedious and time consuming taking nearly a hole day to make one turret. The barrels are made from cocktail sticks (right diameter), the handles are made from pieces of wire and the stock is made from ply and plasticard. The bullets are pieces of wire cut to 3mm long and stuck to a wet n dry paper strip. I tried various materials and methods to make the ammo belts even considered doing it half **** and using tie wraps. My intention was to have them so that they swooped down and round into the flanks of the turret where the ammo boxes would be but after drying and construction being so small and brittle they snapped at any hint of persuasion sideways. In the end i had to either had give up on them altogether or use short belts. My missus justified my failing for me by saying the gunners have used some and nearly out of bullets  :} i felt a lot better.
20mm oerlikon AA
despite being more complex to build than the 50's it took only a few hours to build this. Bits of pen tube, a cotton bud for the barrel and soldered wire for the shoulder pads. It helped that i didnt need to make 100 off rounds of ammo on belt that surely cut the build time down. I enjoyed making this gun. The crosshair site turned out to be about 5mm across, it had been playing on my mind a bit exactly how to go about making such a small cross hair. A brainwave struck me and it resulted in using a holepunch, stamping out a circle in the see threw plastic i used for the windows then etching the crosshairs onto the circle:
Its very small and hardly visible on the camera and doesn't look as wonky as the picture makes out in real life. A bit of jiggling was done after i taken the shot. But you can look threw the rear site into front with the crosshair.  :-))
Anotherthing done is a spot lamp which basically a pen tube with a bit of see threw plastic on the front stuck to a stick, nothing flash and barely worth mentioning. There is however the start to the dashboard with a helm:
its made from a piece of plasticard seeing as its not a wooden wheel i saved me the hassle of making a wooden one and used a material which would splinter less. The wheel is 20mm in diameter to the further most outer edge of each handle. I cut the entire wheel out of one piece of plasticard then using files a thin strip of wet dry rounded each spoke:
I'm afraid to say its not exactly round and blatantly eggshaped if you looked at it close up. I marked it out correctly but cutting it out was a epic task of its own, itl do i suppose.
Still got more to do yet. More dash, liferings, exhausts, bit of lettering and bobs your uncle.
Re: pt-109 build
« Reply #74 on: March 03, 2012, 11:15:20 AM »
I'm afraid to say
Nah .........It all looks great to me - love all the scratch ideas and work involved.  :-))
Tug---Kenny
Re: pt-109 build
« Reply #75 on: March 03, 2012, 11:27:22 AM »
Yes indeed. Very clever with the Scratch building.  (right up my street).
Keep em coming.   :-))
ken
MikeA
Re: pt-109 build
« Reply #76 on: March 05, 2012, 02:32:03 AM »
Well 2 weeks for a boat build might seem a long time to most of you but to me it felt like months!! %% So what have i been up to then?
First i got the controls done. I allways like doing the cabin fittings of any of my builds:
The dash is all mounted on a small piece of plasticard, Ive never used plasticard to this extent before in any boat and on first trial of it wasn't impressed, but now Ive seen the uses for it in the right places and its great stuff. The gauge binnacles are small slices of an cotton ear bud, usually i would go to the extent of putting in the needles and digits but they are just too small. The throttles are made from wire and they the knobs are blobs of solder. To make each one basically i cut the wire first about 3 inches, then using the soldering iron I heated and applied and small blob of solder to tin the ends I then rested the soldering iron on its stand then holding the wire, heated the end again and fed more solder onto the molten tinning i did previously gradually making the blob bigger. I let the solder cool off holding the wire up side down so that a blob would hang off the end, when turning the wire the right way round a near perfect ball was formed. I cut down the wires to approximately 4mm and pushed and glued them into a semi Circle balsa block. Worked out great and was so simple.
Next up was the exhausts.
These arnt shown on the plan but a fairly elaborate feature of the stern demonstrated by images on google. So using a ruler i scaled their dimensions off the SCREEN. It turned out that each muffler was about a 1/3 the length of the height of the transom, so measuring my own transom which is 90mm gave me a length of 30mm. What seemed like the width of each muffler was roughly 1/3 the length i made them 10mm wide. Constructed from plasticard and drinking straws they were time consuming but worth the effort if i say so myself  :-)
Numbers and markings:
The numbers had been bothering me for a while and it was something i eventually had to face. Although MANY models actually show a large white pt 109 lettering on the bow actual photographs of the real thing contradict this. Albeit my boat is semi scale and fairly inaccurate i felt that a slight lean towards reality wouldn't go amiss so they were not included, however the little numbers are. Although the photographs i have here do not show them they are dotted around the boat in various positions. I had considered all kinds of methods of doing the writing, but in the end settled for the cheapest option. It is blatantly obvious they are painted and maybe not well. I could have bought some lettering but i wanted the challenge of trying to paint them myself, which you have to bear in mind i cant paint a door without catching the walls! Its all forward progress in the art of painting :-))
The bow:
I thought it was time i showed the results of the bow. Despite it being constructed out of bits of left over scrap it turned out pretty smooth. The picture makes the paint job look like dog poo but its not as bad as it makes out honestly  :embarrassed:
I have gone as far as the plans have suggested and which i am comfortable with. Im not ignorant to the endless list of improvements and additions that could be made but for me as far as I'm concerned its finished. I got out what i wanted from this build which was to make a simple version of a PT boat, this boat in particular after watching a film. All in all its cost me about 60 quid to make i reckon. I do need an esc yet and that will shove the cost up a bit but ill have to use what Ive got till i can fund one solely for this boat. When i get it on the lake ill make a clip and you can see what happens :-))
« Last Edit: March 05, 2012, 02:34:31 AM by Mad_Mike »
Re: pt-109 build
« Reply #77 on: March 05, 2012, 05:11:21 AM »
You nailed that one Mike.  :-))
What build have you got planned/dreaming of next?
MikeA
Re: pt-109 build
« Reply #78 on: March 05, 2012, 09:03:02 AM »
thanks Dave. Ive got a hole list of things i want to build. When i was gathering the materials for this build i was working but now im not my next build will some what even tighter.
I want to do some jet boat experiments and ive salvaged some rc car parts so i am seriously considering an amphibious vehicle. Simple plans doodled on the back of a fag packet :-)) its going to be a while before i build something grand.  :-)) Ill start a new thread when all that comes about. Until then i will put my funding into a esc and transport case for this boat.
tt1
Re: pt-109 build
« Reply #79 on: March 05, 2012, 10:39:46 AM »
Well done Mike - a true scratch builder if ever there was one.
           Good luck with your next venture, regards, Tony.
MikeA
Re: pt-109 build
« Reply #80 on: March 05, 2012, 10:12:48 PM »
Ive been a bit hasty coming to a close on the build thread, yeah aesthetically speaking its complete but was the boat ready to go? no way! There was still lots to do! %)
positioning the battery:
It was decided at the very beginning what battery i would be using and i was well aware that it didn't fit between the bulkheads, so i dont have a clue why i left it so late to mess around with. In order to get the battery to fit a had to cut a section of the bulkhead out, it is held in position with some off cuts from the 6mm square i used to make the cross member for the servo mounting. All very simple, secure and easily removable.
The ESC and gubbins:
I suppose many people have their ideas about where to place their esc's and stuff, i like a lot of service access. On This boat and actually a few of my others Ive temporarily mounted the esc on a bulk head right under the deck and completely off the bottom to avoid splashing and submersion due to flooding. The receiver is also mounted high up on the underside of the deck near the steering servo to avoid the same problems. I just use sticky back velcro from Wilko, works great for holding batteries still and keeping stuff fixed like deck lids etc. Off course the balance needed checking so in the test tank it went:
This isnt actually the first time ive got the boat wet. The first time was after i had resin doped it to check for leaks, its was still exciting though, especially because this time the boat was working  :}
Firstly i checked the water line:
Due to the position of the ESC the ride was slightly slanted but not much, at slow speed i dont think it would have made any difference but on a plane it might have had an affect, i was hoping the slight offset of the motor from the middle would have counterbalanced the ESC, it did to some degree but needed help. A method i used for ballasting in my trawler was using fish tank gravel, If i remember rightly it was about a £1 for a kilo from wilko, not the plastic stuff either proper stone. Using a sandwhich bag sat on the port side i added pinches of gravel till the ride of the boat was level. I then emptied the sandwhich bag into a balloon tied it up and stuck it way under the deck on the port side:
The method may seem barbaric and crude but it works fine, I suppose lead wheel balancers would be better but this works and cost me nothing, well nothing as far as the budget is concerned for this build. Anyway checked the waterline again:
Im sorry the pictures are a bit fuzzy i was trying my best not to drop SWMBO's camera in the bath %%
While the boat was in the bath the temptation to have a sail was overwhelming, so i had a tootle backwards and forwards albeit very slowly. While i was at it i tried a current test. Holding the boat still and giving it some welly I tried a 10amp fuse, it popped. I then tried a 15 amp fuse, it was fine. I was actually rather surprised and was expecting the amperage to be in 25 - 30's region, goes to show what i know. So i reckon the current draw is about 12-14 amps. I put a 20 amp fuse in to give it some head room but i can go a lot higher if necessary. The esc is rated to 225 amp continuous with a 675A spike limit, although i take these numbers with a pinch of salt. Esc's only temporary till a find another one.  :-))
Anyway its ready for a maiden run now :}
« Last Edit: March 05, 2012, 10:19:20 PM by Mad_Mike »
bluebird
Re: pt-109 build
« Reply #81 on: March 06, 2012, 07:48:02 PM »
Hi there Mike
Nice to see you have finished the build; it looks smart.   Do the plans show any spray rails fitted around the chines of this boat?   If not, it may be wise to fit them – make them out of 1/8 square softwood to run the full length of the boat along the chine.  This will aid in deflecting water from the sides of the hull and give a better performing boat.
Keep on with the build and good luck with your next project.
aye
john
Re: pt-109 build
« Reply #82 on: March 06, 2012, 08:48:39 PM »
Hi Lads
I found this site with lots of links - some to PT boats. Fascinating stuff - of course some of you might already know of it.
http://www.hnsa.org/doc/index.htm
http://www.hnsa.org/doc/index.htm#pt
http://www.hnsa.org/doc/pt/specs/index.htm
Put kettle on and break out the biscuits before viewing these full text declassified Navy documents for researchers of historic naval ships :-))
MikeA
Re: pt-109 build
« Reply #83 on: March 08, 2012, 12:32:56 AM »
I took your advice john and fitted spray rails. No they wernt shown in the plan and it had actually crossed my mind, but since they wernt on the plan i decided not to fit them at first. Anyway they are now  :-))
Took the pt out for its maiden voyage today. Got to the lake only slightly damaged lol, just the front light and part of a torpedo broken. Wasnt suprised at all really it was really combersome and awkward to get under the pushchair but managed it :}
Anyway heres some shots:
I ran the boat till the battery was flat, brought it and opened it up. First thing i got was a faceful of either smoke or steam or something. I checked the motor temp and it was too hot to touch, i splashed it with some water and it boiled off in seconds. I let it cool it down then had another run with a second battery. It came back hot again but I didnt quite run it aslong because i didnt want to risk any damage, i packed it away broke some more bits off and came home. I fixed all the damaged bits then dropped the b***** deck house!! I was quite lucky because it hit the hard kitchen floor and the only bit that broke was a 50 cal and it just needed sticking back on. Dont understand it.
I re tested the amperage to draw to work out why it got so hot. Its still only 10-15 amps which i thought was well within the limitations of a standard 27t 540 mabuchi. The motor is second hand so i think ill get a new one and fit a cooling coil. if that doesnt cure the heat issues ill down size the prop to a 30mm
Now youve read my waffle you can watch some youtube:
http://www.youtube.com/watch?v=CEBLJ757JA8&feature=context&context=C494aab3ADvjVQa1PpcFOvRVGjVP9sCyzeGfg0zNaeqY1ZxOjJUKY=
« Last Edit: March 08, 2012, 12:38:08 AM by Mad_Mike »
MikeA
Re: pt-109 build
« Reply #84 on: March 08, 2012, 09:58:36 AM »
My budget it well limited now basically im down to a handful of coppers, and hadnt planned for the set back of the motor overheating. I need some oppinions. Im thinking instead of going for a 27t 540 i thinking about using a 545:
http://www.ebay.co.uk/itm/Electric-Motor-545-RC-Remote-Control-Cars-Boats-Standard-Size-5-Pole-/230740063773?pt=UK_ToysGames_RadioControlled_JN&hash=item35b92df61d
Im fairly confident that will do it and may not even have to bother using a cooling jacket/coil, what do you all think?
bluebird
Re: pt-109 build
« Reply #85 on: March 08, 2012, 02:21:45 PM »
Hi Mick
that motor in your Link is the same motor that I have fitted in to the Swordsman Model when I upgraded from the first motor I fitted in, from a Johnson 600 to 545. and on a 7,2 pack and on full belt you can fry eggs on the 545 after10 minutes I think you will be better off fitting a cooling coil on the motor you have.
aye john
« Last Edit: March 08, 2012, 02:24:15 PM by Bluebird »
MikeA
Re: pt-109 build
« Reply #86 on: March 10, 2012, 12:36:19 AM »
ordered a new motor and coil today. Also worked on the speed controller, seeing as it does the job it can stay. On the maiden run it go a little warm so Ive decided to plumb it in with the cold water feed.  Few problems arose and took some thinking to work out but got there in the end. Anyway heres what Ive done:
First off i wanted to fit a watercooled heat sink which seemed the simplest solution, that was until i found out that the top of the fets are live and would short out if bridged. I just thought it was the legs that had current in them.
The esc comes with 4 small heat sinks that fit over the fets, theres a fence between the fets that stops you from bridging the fets and causing a short. Obviously then a flat water cooled heat sink bridging all the fets in not an option, I even considered using a thermal pad between the fets and the heatsink, until i found out the thermal pad conducts current as well as heat, No good either! {:-{ I thought about a fan, but considered that the warm air would most likely circulate inside the boat and render the fan pointless. But then for some reason i came up with an idea of combining the two! A small pc cooling fan to cool the fets and what i can only describe as a water cooled air conditioning matrix.
I first soldered brass tubing into a square U shape and made the joint water tight so avoid leaky plumbing. I then soldered wire across the brass pipe work to make the radiator. You can clearly see it on the top of the esc. I checked to see if it worked by plumbing it with some silicone pipe to the cold water tap, and to my astonishment it worked better than i had imagined. The little rad went cold in seconds and after a minute or two even formed a bit of condensation on it!!  %% The pc fan was attached underneath and a box was made to surround the fan and the radiator togeather, the fan was then tapped into the bec circuit in parallel. The motor said on it 3w at 12v which by my calculations is 250ma. The bec makes a 6v supply so the fan is running slower than intended, it still causes a draft but i dont know how much current it draws like this, possibly 125ma? I then painted it matt black as this is the best colour for absorbing the heat out of the air into the water. I know that the rad goes cold but i still have to test weather or not it makes the air cold too. Its theory based at the minute so i got my fingers crossed till the paint finishes drying.
MikeA
Re: pt-109 build
« Reply #87 on: March 13, 2012, 12:18:38 AM »
managed to get all the new motor and watercooling stuff in, bit of a squeeze but im happy with it. got to do a test run though to see how well it works.
Geoff C
Re: pt-109 build
« Reply #88 on: May 29, 2012, 06:11:55 PM »
Hi MikeA,      Very nice job indeed, I've nearly finished one from the same plan pdf but I scaled it up to 35" loa.     If I ever build another one it won't be from balsa wood,  I'll use ply next time.       I glassed the sides and bottom and planked the deck with mahogany strips.     It has a 543 motor controlled by an Mtroniks viper marine 15 with a 40mm brass 3 blade ww2 prop l/handed.      Kind regards, Geoff.      Here's a few pics.
All my senior moments seem joined together these days.          Anglesey, land of the long white beard.
Mad_Mike
  • Lincolnshire
Re: pt-109 build
« Reply #89 on: May 30, 2012, 01:27:51 PM »
great boat. I noticed that you went with the access hatch rather than the vent on the back. that threw me actually and wasnt sure so i stook with the plan in casen i was wrong.
Geoff C
Re: pt-109 build
« Reply #90 on: June 01, 2012, 03:59:06 PM »
Hi Mike,    Yes, I did a load of research into 109 and it didn't have the large E/R vent and access as shown on the plan but everything else is correct.      The next job is a plug-in mast.         I  loved the video on youtube,  she can really shift.       Best regards,  Geoff.
Pages: 1 2 [3]   Go Up
