Model Boat Mayhem - Forum
Author Topic: Can anyone name these motors please  (Read 1383 times)
comtoray
Re: Can anyone name these motors please
« Reply #35 on: February 13, 2012, 07:08:01 AM »
Hi Ray
We were talking about corrosion on another thread and Fleetwood is salt water
so maybe a wash down etc is called for? But maybe already knew that ......
Well i was told about the salt water and corrosion, but one of the Fleetwood guys put my mind at rest, he said it was an old wives tale, hmm id better give it a swill just in case theres nothing lost :-)
HS93
  • I cannot spell , tough
« Reply #36 on: February 13, 2012, 07:20:33 AM »
your boat looks great, and has plenty of pulling power, don't worry about big amp batteries you will get fed up before the battery does,
ER salt water is OK  yer right just make shore you wash the boat in fresh water and keep an eye on brass parts , I am not a fan myself because my boats tend to have all brass fittings  but if you take simple precautions you should be OK.
Peter
wait for the salt water is OK brigade  {-)
comtoray
« Reply #37 on: February 13, 2012, 07:33:36 AM »
Peter
Its done washed off now Peter, i dont know if its true or not there seems to be a few differing opinions, but whats a few minutes thank you...Ray :-))
By the way does anyone know if Fairhaven is salt water {:-{
« Last Edit: February 13, 2012, 07:37:30 AM by ribble fox »
comtoray
« Reply #38 on: February 15, 2012, 03:26:24 PM »
Id just like to add the props and shafts have been took out and greased now just for peace of mind, i dont know whos right as there seems to be a lot of opinions so i will stay clear of salt water from now on O0
john s 2
« Reply #39 on: February 15, 2012, 04:07:19 PM »
All i can say about salt water corrosion is that i brought a boat which had been used in salt water. The five bladed prop looked corroded. On closer examination it was possible t pull the blades out of  the centre hub. The soider had failed. John.
