I have just converted a friends system to 2.4GHz. I used the FR Skye transmitter unit and receiver - both from Giant Cod
. Like other modellers I have suffered the indifference of Robbe/Futaba suppliers regarding upgrades.
The transmitter unit requires but three connections to the transmitter: + positive - negative and the pulse signal. Om the F14 Navy I had the three connections are conveniently placed as three wire links almost in the centre of the circuit board. When looking at the board the nearest is the -ve, the next the pulse signal wire and the next the +ve.
The instructions suggest removing the crystal to disable the 40Mhz but I removed the -ve and pulse signal link wire links to save battery power. Very easy to solder the three links to the circuit board.
The aerial needs to to have a hole drilled in the case to fit the brass aerial connector, and there is a small panel with the control push button and indicator LED that can be affixed to the case. As this set allows for easy removal of the back I just placed mine near one of the switch holes near the top of the case so I could see the LED. Binding only need to be done once and unless you need to set a failsafe you will not need to use the push button.
I placed the transmitter unit above the circuit board on the right hand side - plenty of room, but you could place anywhere in the case to suit your needs as the connecting leads are long.
Checked for correct wiring bad soldering or solder bridges, Attached 2.4Ghz aerial and switched on. LED lit so switched off and followed binding instructions:-
Press and hold transmitter push button and switch on.
Press and hold set button on receiver whilst switching on. (easier to use an on off switch than just plugging the battery in).
Recever light goes green.
Switch off receiver then transmitter.
Switch on transmitter then receiver.
Connect servos and check all channels - 1 to 4 unless you have expanded your F14.
The receiver is 8 channel and cost a fraction of the Futaba receivers.
This system uses a frequency hopping system so should be fairly immune from interference.
There is a link on GiantCod to a test site that gives full details.
Tested on my model last weekend and had full control at all times. The only problem was my sight at extreme range!
I will probably convert all my gear to 2.4 as this system is really good and I have several sets that have been relegated purely because of the band they use.
