Pages: 1 [2] 3   Go Down
Author Topic: pics of u-47 wanted  (Read 10468 times)
offshore1987
  • Good to be back
Re: pics of u-47 wanted
« Reply #25 on: April 06, 2012, 12:25:47 pm »
Sweet  :-))
Piccys?
Daniel
BailingBen
« Reply #26 on: April 06, 2012, 12:30:53 pm »
will do them when i actually get up lol  :embarrassed:
offshore1987
  • Good to be back
« Reply #27 on: April 08, 2012, 06:17:57 pm »
Saw you down there with the sub, level the stern up abit n it should be a good little boat
Daniel
BailingBen
« Reply #28 on: April 08, 2012, 10:29:31 pm »
really were where u u should of said  said hey   and the reason the sturn is down is so the airiel (up boww(coning tower)) stays aboouve water and was actually done by front planes full up
offshore1987
  • Good to be back
« Reply #29 on: April 09, 2012, 12:19:30 am »
But your using normal radio gear? the depth of the lake should not be a problem for the rc gear its only about 2 feet deep
Was with my gf just out for a walk, we sat there for abit n watched the sub then left when you walked around the lake with it
Will be down there maybe tomorrow, or tues and on wens racing from 5pm, let us know when your going next n i will bring the yacht down, always find it better when theres someone else about to chat to
Daniel
BailingBen
« Reply #30 on: April 09, 2012, 01:44:35 am »
the aerial conections looose   and blitchy and ii think the airial got wet so needs replacing      with my micron
offshore1987
  • Good to be back
« Reply #31 on: April 09, 2012, 03:18:19 pm »
Could you not just get a water tight seal then put it through the water proof box and run it up along the deck? just wake abit of glue over the end of the wire to stop water getin inside the wire, thata what my ohio had worked fine  :-))
U-33
  • K-157 Vepr. Akula-11
« Reply #32 on: April 09, 2012, 03:47:47 pm »
Ben...you listening, young fella?
Once you have that boat sorted PROPERLY, report to my office...I have something for you that will transform it.
BailingBen
« Reply #33 on: April 09, 2012, 07:22:51 pm »
sub sorted redid the wiring and new eciever just need the crystals for the reciever as its 40 but the sub was on 27 (mhz)   and i dont have my designated frequence rx crystal (my club as designated crystals )     what sort of transformation u33
U-33
« Reply #34 on: April 09, 2012, 07:38:08 pm »
I want to hear from someone in your club that the sub is working properly and is watertight. Once I have that assurance I will send you an auto leveller, free of charge...once you have it, send it to Sub John, ask VERY nicely, and ask if he will carry out the necessary modifications to it and I will pay him for doing so.
Then you can install it in your sub and away you go. How's that sound?
Subculture
    • Dive-in to Model submarines
« Reply #35 on: April 09, 2012, 07:53:31 pm »
I think this boat is set-up with bow plane control only, Rich.
You could get the rear planes working I guess, but it will require some modification, unless they've been converted already?
BailingBen
« Reply #36 on: April 09, 2012, 08:11:28 pm »
i have thought about converting aft ones and if the leveller cant work on front nes will look into doing it
BailingBen
« Reply #37 on: April 10, 2012, 02:51:38 pm »
am going down lake in 10/15 mins for a run offshore
offshore1987
  • Good to be back
« Reply #38 on: April 10, 2012, 07:01:25 pm »
Was doing stuff with the gf kk, will be down there tomorrow racing yachts, if your about think we are startin at 5
How did she go?
Daniel
BailingBen
« Reply #39 on: April 10, 2012, 08:35:46 pm »
bad rudder issues
offshore1987
  • Good to be back
« Reply #40 on: April 10, 2012, 09:52:57 pm »
She got twin rudders?
Daniel
BailingBen
« Reply #41 on: April 11, 2012, 12:04:07 am »
yhea
but on one thing its just a loose conecton but theres no acces to itand not sure what to do will post pic
triumphjon
« Reply #42 on: April 11, 2012, 08:34:12 am »
dan , smaller motor sailer isnt quite finished , i need to make some double purchase pulleys on the lines , just cant get enough throw on the sail arm otherwise .  so looks as though im going to have to use my 4 ft oyster smack instead tonight . ben have you still got your graupner true blue yacht , you could join in with ?
offshore1987
  • Good to be back
« Reply #43 on: April 11, 2012, 01:39:21 pm »
Im sure we can think up a tool when we see the pics to help you kk
Jon theres some massive clouds over mine atm big black ones  :o rain rain go away come again tomorrow lol
Daniel
Subculture
« Reply #44 on: April 11, 2012, 02:36:43 pm »
Sods law says the most likely part to fail in a boat is also the most inaccessible.
If there is no access, cut in small hatch, and make good.
BailingBen
« Reply #45 on: April 11, 2012, 03:11:02 pm »
when do u sail / race your boats
                                                          kk
triumphjon
« Reply #46 on: April 11, 2012, 03:43:12 pm »
sailing takes place , wed eves from around 5 ,& saturday mornings 1030 till 1 ish , the brighter weather was following me back in from eastleigh just now !
romanjohn
« Reply #47 on: April 15, 2012, 11:03:00 pm »
ben can you get the fittings for your destroyer then something might work in your fleet romanjohn
BailingBen
« Reply #48 on: April 16, 2012, 03:16:47 pm »
what do you mean by fittings
triumphjon
« Reply #49 on: April 16, 2012, 07:17:21 pm »
kk ,i think he was needing all of the kit to make it operatable , ie motor / shaft (s)  speed controller , rudder servo etc . i spoke to john on saturday
Pages: 1 [2] 3   Go Up
Page created in 0.098 seconds with 22 queries.
