Model Boat Mayhem - Forum
Author Topic: Hull advice  (Read 1853 times)
lakeshore
Hull advice
« on: April 09, 2012, 09:17:56 AM »
Thinking of purchasing one of these hulls made in GRP  49'' long 11'' wide and 8'' deep, any idea's as to what the design is as the maker not sure of what plan if any the hull is from.
pompebled
Re: Hull advice
« Reply #1 on: April 09, 2012, 09:27:54 PM »
To be honest, I have no idea what the picture is supposed to show...
Do you have a link to the hull in question?
Regards, Jan.
tugboyben
  • http://kirkleesmodelboatclub.org.uk/ http://www.balnemoormbc.co.uk/
  • NUMAS WARRIOR
Re: Hull advice
« Reply #2 on: April 09, 2012, 10:17:04 PM »
Mad_Mike
  • Lincolnshire
Re: Hull advice
« Reply #3 on: April 09, 2012, 10:51:04 PM »
defiantly that hull with the image flipped for some reason. what do you think it would suit as lakeshore?
lakeshore
Re: Hull advice
« Reply #4 on: April 10, 2012, 06:50:36 AM »
Not sure what the hull is suitable for, thats why I came into the forum to ask for advice.
Mad_Mike
  • Lincolnshire
Re: Hull advice
« Reply #5 on: April 10, 2012, 11:00:58 AM »
i know that fella but i meant from an artistic perception. It could be anything, its not a trawler or tug because the prop and stern is wrong. and i doubt it a military vessel it looks like some kind of small launch or day fishing boat.
Tug---Kenny
Re: Hull advice
« Reply #6 on: April 10, 2012, 11:02:54 AM »
Have you enquired from the builder what he copied it from ?
ken
lakeshore
Re: Hull advice
« Reply #7 on: April 10, 2012, 11:31:06 AM »
I have asked the builder what plan or plug it was made up from, but he says he cant remember only that it was for general use when he got it and that it should be suitable for Liner - Car Ferry - Warship.
John.
Re: Hull advice
« Reply #8 on: April 10, 2012, 12:32:02 PM »
Which is a nonsensical statement! Surprised he didn't suggest rowing boat as well..... (or even dog bath)
Re: Hull advice
« Reply #9 on: April 10, 2012, 09:26:56 PM »
Quite.  I suspect that the "maker" isn't.  If I had made something that size, I am very sure that I would have had a use in mind, and I would certainly remember what that use was.
You don't really know until you try, but that depends on what you're trying.
NickelBelter
Re: Hull advice
« Reply #10 on: April 11, 2012, 02:49:32 AM »
He might have laid up the hull but he definitely did not do the mould, otherwise he'd know what it was meant to be.
Strangely enough the two most suitable ideas aren't listed:  medium size patrol boat or large scale cabin cruiser.
lakeshore
Re: Hull advice
« Reply #11 on: April 11, 2012, 02:36:19 PM »
Decided to go ahead and order one in any case, made mine in white gellcoat, pics of finnished hull to follow.
John.
lakeshore
Re: Hull advice
« Reply #12 on: April 11, 2012, 02:37:48 PM »
another.
lakeshore
Re: Hull advice
« Reply #13 on: April 11, 2012, 02:39:25 PM »
another.
John.
SunnyBob
Re: Hull advice
« Reply #14 on: April 11, 2012, 06:55:18 PM »
well the front and middle are definitely most like a cabin cruiser, but that rear is very deep and rounded. i would think a single engine and rudder wold be best, other wise the slope is going to make rudder mounting extremely difficult.
Re: Hull advice
« Reply #15 on: April 11, 2012, 07:29:33 PM »
Hey Sunnybob - when I saw you here I was expecting to see a sig pic test 5
SunnyBob
Re: Hull advice
« Reply #16 on: April 12, 2012, 07:25:05 PM »
check out the "insert image " thread, I got hi jacked, robbed, and ended up with a redex for my troubles.  {-) {-)
but I've mastered the old insert here trick.....,
you can see why I think this hull is too rounded on the stern for a cabin cruiser, or as mine was originally labelled when made in 1949, a "Gentlemans yacht"
Artistmike
  • North Devon
Re: Hull advice
« Reply #17 on: April 13, 2012, 08:47:30 AM »
And a very lovely looking yacht that is too ! I've not seen any details about it, what sort of size is it may I ask.  :-)
SunnyBob
Re: Hull advice
« Reply #18 on: April 13, 2012, 05:02:42 PM »
there is (or there was) quite a history on here about the boat. Try searching for "gwen eagle"
its a 1/12th scale, of a 40 ft motor cruiser. my dad built it 50 years ago but never got the internals done. I finally got it in the water 5 years ago. Brought it to Cyprus with me 4 years ago, and have had horrendous problems ever since. Its made of mahogany strip planking, and the summer heat here opens the planking cracks. I've just fibreglassed inside and out, and fitted new shorter prop shafts.
the blue paint is not good, but at this stage i just want to get in through our august temps (40c most years, went to 45c 2 years ago).
If it gets through this summer without cracking, i shall repaint to a better standard.
Artistmike
  • North Devon
Re: Hull advice
« Reply #19 on: April 13, 2012, 05:38:01 PM »
Well, it's a beautiful looking model and you're right, the history on here is unavailable unfortunately using the normal search methods after our recent forum problems. However having done a "Google" I managed to find your original thread....  http://www.modelboatmayhem.co.uk/forum/index.php?topic=10059.0    :-))
That is a model I'd love to have a shot at ...... totally classic lines and your father made a beautiful job of it.  :-)
SunnyBob
Re: Hull advice
« Reply #20 on: April 13, 2012, 05:52:10 PM »
the forum is very strange at the moment. i just did a search for gwen eagle and got nothing. then I tried again with Gwen Eagle (capitals) and got everything.
When I finally got info about it, I managed to get a set of plans from  a company in scotland. When they arrived they were not a true 1/12th, the plan gave a boat about 30". i took them to a copy shop and asked them to scale it up to the full 39". Man, what a project that was! It took them about 6 sheets of AO to finalley get the correct size. I helped dad when I was around 10 years old. We steamed every plank over a large saucepan of boiling water. drove my mum crazy  %% >>:-( ;)
lakeshore
Re: Hull advice
« Reply #21 on: April 15, 2012, 09:10:46 PM »
Well the hull arrived a couple of days ago, quite a nice gellcoat and overall a good fibreglass thickness. The only problem is that it has a slight twist in it when looking along the gunwhales, so went off to good old B&Q and got a 50''x24''x1'' mdf building board. I intend to clamp the hull down to the board slightly using 5mm threaded bar and a ply block over the gunwhales to straighten the hull out. While in this jig I intend to fit the bulkheads at least the main three. I thought that if the bulkheads were fitted while the hull is clamped in the jig then any twist would be built out of it (hopefully). Basically anyone done this to get a twist out or is there a better way of doing it ??.
John.
Re: Hull advice
« Reply #22 on: April 15, 2012, 09:30:51 PM »
Locking the hull in place is necessary. Then go over it with a hot hairdryer until it is quite warm, almost too hot to touch and then let it cool off in which case it should settle into the corrected shape.
A bit of distortion in GRP hulls as they cure is quite common but the heat treatment will usually sort it out.
nemesis
Re: Hull advice
« Reply #23 on: April 16, 2012, 06:45:16 PM »
Hi, Looking at the length to beam ratio together with the stem & keel it could be a transomed fishing boat hull. Nemesis
lakeshore
Re: Hull advice
« Reply #24 on: April 20, 2012, 07:26:12 AM »
Thank's Colin
managed to get the twist out, clamped in the jig using the heat treatment no problem, the question I have now is how to accurately measure the inside of the hull for the bulkhead templates. I have made a couple using cardboard but am having problems with the third, just wondered if there was an easier way of doing this.
