fix the floor support to the rear engine compartment bulkhead, and fit these in place DD NOT Glue in place yet. Next drop in the engineroom floor, you will probably have to tilt the rear bulkhead backwards to get the floor in, then push it all together. Now jump ahead a bit and open up the hole in the hull for the shaft and slide it into place, through the hole in the bulkhead, you will, eventually have toreduce the length a little to accomodate the steam plant. Now is the time to start planning the engine room layout, it will be very different to what is shown on the plan as you are using a horizontal bouler, but dont worry, it will all go in. Well, that should keep you busy for a little while, I will post some photos when I get home tomorrow or Saturday. Oh, and dont worry about the paintwork just yet. Happy building and good luck.
