Author Topic: Smoke Units  (Read 4280 times)
galleyboy
  • How they laughed when I said it would float!
Smoke Units
« on: May 07, 2006, 09:35:07 pm »
Hello Everyone. Just a bit of advice needed please. Are there any good or bad units out there? Are they worth the expense and effort? If so which is the best value for money? Do they 'smoke' good? Or am I just as well setting fire to a few incense/joss sticks and shoving them down a fireproofed funnel. I've seen the new unit on the WWW but it looks a bit like a forced draught boiling kettle and I'm looking for that diesel type blue/black smoke.
Many thanks. The galleyboy
aston
Re: Smoke Units
« Reply #1 on: May 07, 2006, 10:39:42 pm »
If the new unit you are talking about is the one from JJE elecctronics, it is indeed forced draft ( from a fan) but is certainly not boiling. It is completley cold water vapour.  It works, Jim tells us, by a unit which creates tiny water droplets which are then blown up the funnel or whatever by a small fan.  Good points are that as there is no heat involved, then 1, it is instant (no heating up).  2, it can be piped from the unit to it's exit point ( funnels, exhaust pipes) in palstic tubing as there are no heat concerns, and 3, because it's water mist, you can add food dye directly to the water and get asny colour "steam" that you want.  try adding some rdark blue and look what good diesel smoke you get !
Aston
galleyboy
Re: Smoke Units
« Reply #2 on: May 08, 2006, 09:20:20 pm »
Hello Aston. Many thanks for the excellent reply. I shall investigate the JJE unit.
Tom Eccles
Re: Smoke Units
« Reply #3 on: May 20, 2007, 08:47:23 pm »
This info about smoke units is very interesting. Can the unit be linked to an ESC? also, I am building a steam tug but it will have electric power, are there any good sound modules for a triple expansion engine that anyone has tried?
Tom
Re: Smoke Units
« Reply #4 on: May 20, 2007, 08:58:54 pm »
Westbournes sell the JJC sound system:
http://www.westbourne-models.com/images/Sound-file/PE301.mov
Richard ;)
catengineman
Re: Smoke Units
« Reply #5 on: May 20, 2007, 08:59:15 pm »
Tom
Yes the Old Smokey mk2 unit (I fitted one to a tug the other day) has four modes I think ranging from diesle to puffing steam and then there is the display mode (on without ESC control)
On the tug I arranged it to run from a single switch rather than an ESC as there are two ESC's in the tug it would only run if the one connected was used. With a twin motor driven vessel I think it would require two OS units.
These units are just great and come complete with the control board and connecting lead to connect to 1 ESC plus the instructions mention sound modules from the same company.
Get one have fun and see the "smoke" it will make
Richard,
justboatonic
Re: Smoke Units
« Reply #6 on: May 20, 2007, 09:36:15 pm »
One of these JJC OS is deffo on my shopping list for the MS Envoy.
However, I thought Id heard say dont add food dye as this can leave a sticky residue. Is this not the case?
catengineman
Re: Smoke Units
« Reply #7 on: May 20, 2007, 09:53:20 pm »
Hi, I think you may have heard similar and it is coffee for colour that left a sticky residue
I think it is in the instructions about the coffee
Not had food dye in the system I fitted as it belongs to capt jack and is in his tug.
Richard,
gary r uk
Re: Smoke Units
« Reply #8 on: May 20, 2007, 10:07:40 pm »
hi
no food dye & no 6 volts .
don't tilt it if you ever have to take it out,water will spill out through the fan oh & when you think its empty it won't be.
the instructions are very vague they don't tell you much and there is no difference  between the Mk1 & Mk2 smoke units.
cheers
gary rowe
SAILING WITHOUT FAST ELECTRICS PRICELESS
Umi_Ryuzuki
Re: Smoke Units
« Reply #9 on: May 20, 2007, 10:46:52 pm »
The JJC smoke unit takes well to plumbing also...
 8) 8) 8)
catengineman
Re: Smoke Units
« Reply #10 on: May 20, 2007, 11:01:31 pm »
Hi, I see you fitted the OS to your build of the Tito Neri,
I ran out of room in the hull as well as money  :'( but I still may jiggle things around to try and get one in, I did build into the funnels pipe work ready
Richard,
spoons
Re: Smoke Units
« Reply #11 on: June 18, 2007, 11:23:49 pm »
Hi I have fitted the jjc electronics old smokey to my illustrious the unit is very good and i have had no problems with it atall i currently have it connected through my port speed controller and have two of his sound cards through my stbd controller.The only problem i see is the space it takes up but thats okay my model as i have quite a lot of room.
