Hi there the build has started at long last !
First off a bit of preperation of the frames and the centre keel.
The parts were removed from the surrounding wood and the edges were lightly sanded to remove any rough edges (lots of >:( )
They were then marked up carefully and 1/8 sq ply was used to create small strips to support various parts during the build . Definatley a case of measure twice stick once ! I kept mixing up the centre line ,on some of these strips , with a line 1/4" away from cantre to place them ! Still I got there in the end :)
Frames all prepared ready for fitting .
Next it was onto the centre keel which came in 2 halves and required gluing together to make one keel 1/4" wide . Why on earth they didnt just make it a one piece affair is beyond me .I was tempted to recut it from marine ply but didnt have any to hand in the required thickness so opted to do it as per the book .
centre keel glued together .
While waiting for that lot to go off I started on joining the 2 sheer halves together ,again why 2 pieces when 1 would have been easy enough to cut :-\
Sheers glued
Then after a couple of hours to allow it all to dry properly I started on fitting the frames into place paying carefull attention to the angles of each one as it was glued into place .
I tacked them into position first with thick CA . FLJ you are correct CA and mahogany dont like playing together
But it did hold while I used the aliphatic around and between the joints .
And this is where I am up to now
All the frames fitted and setting solid overnight .
Tommorow I have to fit the Chines which should prove interesting as it involves laminating 3 strips of 1/8 x1/4 x 45" of spruce together down the whole length of the framework . I may ,having thought about it ,glue about 2" together at one end and then glue the rest as I am progressing down the length of it thereby allowing each piece to pull along each other as it is going so removing any unnecesary stress while its being curved .
More soon
Shane
