Thanks Greg,
Yes, this is based on the "stretched" 30ft version plans that SF built for a South African vineyard owner.
The new launch's performance will be interesting compared with the primitive hull of "Vital Byte". What do you mean by "too much displacement" - is it the shape?
I suppose what I'm trying to achieve is not so much speed, rather than an elegent and luxurious application of steam power that you don't get with anyother craft. The Edwardian period of steam pleasure boats seems to encompass that tone. Also, it is a type of craft where the steam plant can be legitimately displayed in all its motion.
I wonder if you can help me on a few points - in the SF manual it describes the launch as having a "deep forefoot" on the bow - what does that mean? And, also, what is the correct description of the bow shape - is it a schooner, Thames launch, Windermere launch, etc?
Hi Ian,
Forgive me, I notice now your first post does indeed say it's the 30ft'er.
Your launch will indeed have elegance, in bucket loads!!
As sailorgreg says, that bow would normally be described as a 'clipper' bow, although in essence they are two completely different constructions of stem, a different name for the general shape your boat's bow hasn't until now been though of. One feature of a clipper bow is a deep forefoot- again, as sailorgreg points out, this is the point where the stem meets the keel, often curved on launches, it provides a wider land for the planks to land on than if you took the planks onto a completely 'plumb' stem- imagine your planks continued onto a stem that was 90deg. to the waterline, how acute the angle would be.
I have to disagree with sailorgreg on the point of displacement- steam launches have a direct correlation between displacement and speed, or more accurately between displacement and power consumption. A case in point- steam launch 'Elfin' on Windermere was 65ft x 6.5ft- a beam to length of nearly 1:10. She had a 250hp compound engine and had a speed of 25mph, in 1895!! She would have had a displacement of around 12-15tons. Compare that to the preserved steam tug 'Kerne', she is 72ft LWL (longer WL means a more efficient entry and exit angle, and usually more speed is resultant). She has a beam of 18ft and a displacement of 63tons. She has a 300hp triple turning prop' of nearly 8ft dia!! Yet, with all that power she can only reach 8knots at full speed. Why, because she has to push 63tons of water out of the way just to float.
Having seen a large number of launches that were designed and built
during the Victorian/Edwardian period it is distinctly obvious that SF's designs, although very seaworthy and very pretty, do not in any way copy the launches of the period they are titled after.
I know of two boats that were built in the last 15 years or so, one 30ft, one 31ft. The 31ft launch has a displacement of just 1.2tons, uses a single cylinder Thornycroft engine of just 8hp, and yet will reach and sustain 16mph! The other 30ft launch has a displacement of 1.1tons, a 15hp LIFU compound engine and a top speed of just short of 18mph- very impressive to say the least.
In low powered, highly efficient steam launches, displacement is everything, not that any of that will stop your launch being a very well designed, built and engineered boat, of which that is already evident.
Greg
