Just a couple of additions to the project.
I’ve made the deck gratings using ¼ inch mahogany strips – I started by hand, but quickly made a milling machine jig to speed up the process.
I thought I could just slice through the mahogany with a 6mm end-mill leaving a clean cut, but I found that the grain caused rather a ragged cut. I had to do initial cuts with the razor saw before milling the lap joint groove and then finishing off with a fine file.
All in all, I had to cut 720 grooves to make the two gratings. The first grating took several days, but the second 4 ½ hours.
I subsequently found out from a friends full size Dutch barge that the gratings are of two thicknesses of wood with a groove cut only in the lower one!
The brass jig was designed with a drop-down gate that located the wood and held it steady for the next cut.
The other new development is the replacement of the cable connected Control and Display Unit , which interfaces with the on-board computer, with a new one that incorporates a two-way 2.4GHz radio link (See thread
http://www.modelboatmayhem.co.uk/forum/index.php/topic,48575.25.html ).
This will enable me to fill the boiler remotely, supervise the fuel gas supply pressure and even tune the control loops when Vital Byte is in the middle of the pond (and I’ve just started on the MP3 sound system to link in with the anticipated phonograph!)
Last weekend, VB10 was displayed at the Ally Pally Engineering in Miniature exhibition on the Kent Model Boat Display Team stand.
A French couple, Francois and Isabelle, came from Paris especially for the show; they were friends of French Mayhem member “rhavrane” (Raphaël Havranek). There were also three guys that had come all the way from Vienna!
