Thanks for this, Spearfish. Our prices have had to be 'revised' - a lot! Units now £20 (4-cell) and £24 (5-cell +). Both include UK P&P.
It's not been a good day..........
DM
Hi DM,
Can I assume from your remarks that what I have bought is one of yours?
I have had the chance to try the little beast out on the Futaba set up that I intend using with the Zen. It is a T6EX transmitter (2.4 Ghz) using a FrSky compatible Rx on 6v. With the failsafe turned off on the transmitter, you can set the RX to use what control positions you want in the event of a loss of signal, e.g throttle fully closed, full right rudder or whatever.
Using this unit , I can switch off the motor using Ch5 at will as this is the 2 position channel intended for undercarriage on this Tx when used in a plane. On switching off the Tx to mimick loss of signal, the throttle closes and the unit activates and cuts the ignition to stop the Zen by earthing the black wire from the coil. Just like it says on the tin or rather the extremely clear instructions provided with the unit!. Really very pleased with this. Now just need to buy a second one to go with the other Zen.
I was wondering how best to mount it close to the engine while keeping it clean and dry. Just realised (being a photographic dinosaur still using 35mm film) that it fits very easily into a 35mm film container which should be very easy to postion in the boat and to seal. Fits into one of those Terry spring tool clips for easy access.
