Thanks everyone for the advice and encouragement. It's nice to know I'm not alone!
Jerry, I am sure the oiler is working - the oil is going somewhere, and I drain water out of the lubricator. Don't know the sae (I just bought steam oil), but yes, it is like golden syrup. I ran for about 2.5-3 hours on air and made sure everything was well oiled when I did so. Everything certainly feels smooth and easy when you turn the cold engine over by hand. George, I think you are right, my problem is probably hydraulic lock, because when I turn the cooled engine over by hand, spurts of water come out the exhaust. I don't have a steam drier at the moment - just straight out the boiler and into the engine. There seem to be plenty of TVRs running perfectly well without drying the steam. Maybe something for the future. However, I did put on some temporary lagging -
OK, not too pretty at the moment but better than nothing. Derek - I haven't contacted Graham Industries at the moment - I think there are more things I want to try first to see if I can crack it.
I also had an exchange with Mike Abbott about the pressure gauge. He had set it to 30psi, which explains that, and was perfectly happy for me to adjust it. I did so, although I didn't really know how much to turn it. I think I did about 1 full turn or a bit less, and as we'll see later that seemed to do the trick.
The other lesson I have learnt is about filling the gas tank. Previously I stopped filling when the liquid gas bubbled out around the filler, but I have now discovered that you need to pause, then fill again - and again. I had about 5 or 6 goes before I could feel a reasonable amount of gas sloshing around inside the tank. I also have been following the advice on the Mainsteam site not to hold the tank when filling it. You want a warm canister dispensing the gas but a cold tank receiving it to get maximum pressure difference between the two.
So of I go again, fill the boiler and light the gas. The safety lifted at about 50psi by the boiler gauge and I opened the steam valve. The engine started, ran for about a minute then slowed and stopped.
I moved the reversing lever back and forth, spun the flywheel and the engine ran intermittently. After a few stops and starts I discovered that if I left the lever in the "economy" position at the bottom of the detent bar (ie one slot up from the bottom), the engine ran fine. If I tried to change direction, it stopped and only ran intermittently. Similarly, if I moved to the very bottom slot, it ran slowly and then stopped. Only in that one position would the engine run well. So I left it there and had a 20 minute run. I could adjust the speed with my throttle, from a slow tickover to - well, fast! I tried a few times to reverse the direction or use the "fully open" position, but with the same result. The boiler pressure was about 35psi during the run.
So, success! My engine has run on steam until I stopped it, not until it stopped itself.
But it is still a little way from being reliable in forward and reverse - and I am puzzled by it running in the economy position but not in the fully open position.
Other than some more careful checking of the timing, is there anything else I should be looking at?
As the old British Rail slogan used to say - We're getting there!!
Greg
