Phew! That was a hectic Christmas. Still managed to find a few a moments to play with the steam engine. I changed the slightly long bolt in the linkage for the original screw and that reduced the movement a little bit. Once I am fully sorted I'll shorten the hex head bolt and put that back. For the moment I'm focussed on getting the engine to run reliably. I checked all the points suggested by George and made sure I really was reading the timing instructions correctly - I was! I have also played with the timing a fair bit. I am realising that a tiny adjustment on the valve stem (screwing up or down a fraction of a turn) can make a noticeable difference to the smoothness and reliability of the engine. It is certainly getting better, and if I set it going and leave it alone it keeps going. It will change direction (fairly) reliably - occasionally needs a to-and-fro on the lever to get going again - and responds well to the throttle as long as I keep the engine running. However, if I try and stop it by closing the throttle and then open it again, I sometimes get the "locked solid" feeling. I can't even move the fwd/reverse lever, the engine won't turn and I have to leave it for a while before gently wiggling it back to life. This is something to do with running on steam - the engine will run all day, stop, start, tick over or race when I use compressed air, but steam seems to get things binding up somehow. Nevertheless, things are getting better and I will persevere.
Santa was as good as his word, and I now have something to take my steam plant afloat.
This was ordered quite late in the day and I must applaud Models by Design who still got it under the tree in time for Christmas. Great service!
I am not sure I will use the deck moulding. I'm not too keen on the way it narrows in the forward part. Apart from anything else, my fat fingers are going to need all the space they can get! Nothing decided yet, but I'm drawing plans for wooden deck beams and planking and when I've done that I'll make my choice. Incidentally, is there any reason that I shouldn't build my water tank into the bow rather than having a separate tank? It seems perfectly straightforward to glue in a couple of bulkheads to form the tank, but nobody seems to do it that way. Why?
Well, I guess it will be next year before I report any more on this, so Happy New Year to everyone, and let's hope the weather in 2013 is a little kinder for boats and sailing.
Greg
