Author Topic: using PU glue  (Read 2371 times)
tobyker
using PU glue
« on: September 19, 2012, 12:37:53 pm »
I like one-part PU glues like Balcotan and Gorilla glue. I used Balcotan for a 14' sharpie with no nails or screws left in, and use Gorilla glue, as it comes in very small containers, for model work. It's not worth buying anything bigger than the 60ml size because once opened the shelf life is not all that long. However, the top of the bottle always seems to seize up, requiring energetic work with a pin or scalpel to get to the glue just when you've got all the bits precariously balanced prior to gluing/assembly/clamping.
Toby's Tip: put the cap back on the bottle but store it upside down in a small jar or whatever. Then the bit by the nozzle will stay liquid ready for use.
Apologies to all those who know that already, but it might help someone.
Stormbringer
Re: using PU glue
« Reply #1 on: September 19, 2012, 01:32:28 pm »
also if you keep ca type glues in the fridge it increases the shelf life a lot longer
Re: using PU glue
« Reply #2 on: September 19, 2012, 01:35:14 pm »
This also works for the Humbrol/revel tinlets and stops the skin forming on the top.  A quick dab of coulour on the bottom helps as well
Page created in 0.117 seconds with 21 queries.
