I'm not totally sure where your diagonal line (5) is going from.
Here's what I did with the Dreadnought. (WARNING! Excessive scribbling on The Book follows. Viewers of a nervous disposition, and those who foolishly believe in my sanity ought go to another thread now.)
Below is part of the page covering the waterlines. Top is an elevation, middle is a plan (both in a useless-to-me 1/384th scale) and bottom are cross sections (1/192nd scale). The waterlines are parallel to the keel, and lettered A, B, C, etc. M is main deck, U is upper deck, and Fl is foredeck. These are not parallel to the keel.
How far apart are the waterlines? With careful measurement, the
best fit of the distance from G to A in Imperial Units (what the ship was built in) makes each waterline four feet apart. The lowest waterline (G) starts 2'6" above the keel. On a BIG sheet of paper I drew the elevation view first - a line for the keel, and parallel waterlines above it. G, at 2'6" is 5/12" at 1/72nd scale. Four feet apart is 2/3rds of an inch. Once done, I plotted the section positions on the elevation (they're 24'6" apart for some reason) marked these (they're lines perpendicular to the keel) and measured the deck-edge heights and marked these on the big elevation. These non-parallel points were joined with smooth curved lines.
On to the big plan view: above the elevation's highest point I left a gap and drew another keel line, parallel to the waterlines and the keel line of the elevation. I marked out the section positions on this and drew these lines (once again perpendicular to the keel).
Now to the maths:
The handy scale below this elevation shows station positions. WTB stands for watertight bulkhead. The forward perpendicular (FP) is the bow at the normal waterline. The aft perpendicular (AP) is the axis of the rudders. I know Dreadnought was 490' between these perpendiculars (PP), and 526' length overall (LOA).
Now, the station positions change in length along the hull. And with a bit of care, you can see that there are 38 & 2/3rds from FP to station 40. There are 160 somewhat longer ones between station 40 and 200 (off the page), and 18 between 200 and the AP. Given the forward and aft stations are 3' apart, and the central ones 2' apart (4' in the drawing, but they're number evenly and there are no "odd" stations used in the plan) you get 490'.
The book shows good elevations of the bow and stern at a larger scale, with stations and bulkheads in place which enabled me to scale up and draw the bow and stern elevations on the right stations to get the correct LOA. Result!
On to the big plan view. Knowing the beam of the Dreadnought I knew the maximum width that the plan could be. Scaling up the cross-sections I could plot the waterlines onto the plan, making sure the maximum breadth didn't exceed the known beam. These points were faired, and from the big plan I took off this information to make a few trial sections at my desired scale. With a little bit of tweaking of the waterlines on the plan, all became correct enough (within a mm).
Now I could mark out MY positions for frames for building: these are 18' apart (3" at scale) and run from station 4 aft. Following this it was trivial to draw out sections using the big plan's waterlines and deck edges as a guide.
The cross section shown in the first image is the edge of the frames: hull plating adds to this (and during a build, the widths of most battleships "fell open" a few inches or so.) On my plotted sections, I removed 3mm from the outer edge to get a frame which would "return to accurate" once 3mm of hull skin was put on.
And there you go.
I must admit, it was extremely useful to have the big plan and elevation to accurately nail the turret centres, funnel and superstructure positions - these all coincide with stations. "A" turret at "54", for example. And it was very useful to draw onto these images prop shaft centrelines (in plan and elevation) which enabled me to pre-drill holes in my ply frames to locate them during the build.
I don't know if this is how anyone does it, but - for scaling up small scale plans (which are somewhat useless) to recovering their accuracy, works for me.
