Pages: 1 [2] 3 4 5 6 7 8   Go Down
Author Topic: Open type ferry  (Read 65736 times)
bassplayer1
Re: Open type ferry
« Reply #25 on: April 29, 2013, 07:20:46 pm »
Thanks for the nice comment Alex! Finaly I've managed to get me some free time and I started to fix the frames for the car deck! Sorry about the quality of the photos!(my son took the other camera). More to come!!!
mark w
  • "I stick my neck out for nobody"
Re: Open type ferry
« Reply #26 on: April 29, 2013, 07:28:05 pm »
Very nice  :-)) .
Mark
"If she can stand it, I can too, play it"
bassplayer1
Re: Open type ferry
« Reply #27 on: May 02, 2013, 10:04:54 pm »
bassplayer1
Re: Open type ferry
« Reply #28 on: May 04, 2013, 08:13:46 pm »
Good evening everyone!
Some more progress on the subject! Made the rudders out of 5mm marine ply and they were given 5 coats of polyurethane varnish. I carried on making the motor mount but is not glued yet in position, just checking out! Also made some floating test, looks good so far! More to come!
obxships
Re: Open type ferry
« Reply #29 on: May 06, 2013, 01:18:35 am »
Your build is looking great, look forward to seeing more. Looks awesome on the water.  :-))
Regards, Dennis
bassplayer1
Re: Open type ferry
« Reply #30 on: May 07, 2013, 12:42:18 am »
Thanks for your kind words Dennis, they're much apreciated!
Re: Open type ferry
« Reply #31 on: May 07, 2013, 08:51:13 am »
Looking really good.
Not a run of the mill model but the only one on the water. :-)) :-))
Do you get any problems with the motor mount bulkhead acting as a sounding
board to amplify any motor sounds?
bassplayer1
Re: Open type ferry
« Reply #32 on: May 07, 2013, 07:33:31 pm »
I wouldn't think so Ned. Thanks for the kind words!
boathound
Re: Open type ferry
« Reply #33 on: May 24, 2013, 04:58:47 pm »
Oh wow, fantastic build and brilliant subject. Can't find a ferry hull for love nor money  :((
bassplayer1
Re: Open type ferry
« Reply #34 on: April 03, 2014, 10:28:02 pm »
Hi everyone!
After a long time I've finaly managed to do a little work on the project! :-)  I glued some pieces on the car deck and also did some tamplates for the bridge! Hopefuly tommorow I'll finish then off and start cutting in styrene! Some pictures!
mark w
Re: Open type ferry
« Reply #35 on: April 03, 2014, 10:30:39 pm »
Very nice  :-))
Mark
TugCowboy
Re: Open type ferry
« Reply #36 on: April 03, 2014, 11:27:56 pm »
Still looking great.
Will enjoy seeing the next stages.
Alex
Re: Open type ferry
« Reply #37 on: April 04, 2014, 12:57:04 am »
Yannis......without knowing the motor sizing or loadings........you may wish to consider cutting some kidney shaped slots in the motor mounting plate to match the air cooling slots in the headcap face of the motors...Derek
bassplayer1
Re: Open type ferry
« Reply #38 on: April 04, 2014, 01:24:03 am »
Mark, Alex, thanks for the kind words :-)
Derek, I'll do that! :-))
GAZOU
Re: Open type ferry
« Reply #39 on: April 04, 2014, 08:59:41 am »
It is some cardboard?
He is going to navigate, with what to protect you the cardboard?
TugCowboy
Re: Open type ferry
« Reply #40 on: April 04, 2014, 10:33:42 am »
I believe the cardboard is just a template to get the shape right and will be replaced with styrene sheet, if I read the original posts correctly.
bassplayer1
Re: Open type ferry
« Reply #41 on: April 04, 2014, 10:05:20 pm »
That's correct :-))
obxships
Re: Open type ferry
« Reply #42 on: April 06, 2014, 01:12:36 am »
Looks like it is starting to take shape. looking great!! :-)) Also like the use of the cardboard for a pattern material, will have to keep that in mind when I start my sport fishing build.
Regards, Dennis
bassplayer1
Re: Open type ferry
« Reply #43 on: April 07, 2014, 12:13:54 am »
Thanks for the kind words Dennis! :-)
bassplayer1
Re: Open type ferry
« Reply #44 on: April 07, 2014, 12:22:38 am »
More progres! Started working on the upper bridge in styrene sheet. Also made the pavements(if I say it correctly???) for the passengers port and starboard. Here is some pictures!
Re: Open type ferry
« Reply #45 on: April 07, 2014, 12:27:56 am »
Just found this build log while looking for something else - a great subject and great workmanship, well done so far :-))
The passenger pavements would be termed "walkways" - I think that's what you meant O0
Re: Open type ferry
« Reply #46 on: April 07, 2014, 01:50:23 am »
Yannis.... very interesting :-))
1. I see the vehicular ramp is functional......
2. I also see from the first posting image the fulcrum lifting point is strangely low @ approx. 1/2 of the total ramp length
3. We also see safety chains fitted  %)...are the chains to support the ramp's water tightness @ sea?...as the chains appear to be non tensioned ...or slack in this image
4. Is the construction of your ramp sufficiently lead weighted to allow it fall under it's own weight when lowered via the wire cables?
5. Will you use some form of gasket between the inner ramp edges & the hull to maintain water tightness?
Derek  ;)
bassplayer1
Re: Open type ferry
« Reply #47 on: April 08, 2014, 08:50:13 pm »
Thank you Ray, that's much appreciated
bassplayer1
Re: Open type ferry
« Reply #48 on: April 08, 2014, 09:09:25 pm »
3. We also see safety chains fitted  %) ...are the chains to support the ramp's water tightness @ sea?...as the chains appear to be non tensioned ...or slack in this image
Derek  ;)
Hi Derek
I supose the lifting point of the rump is low to save some travel as it's operated pneumaticaly by a little piston which is located on the small deck just above the rump! The chains are always slack and they're there just in case! The rump itself is heavy enough(no lead) to lower by it's own weight and no, I'm not going to use any gasket as it doesn't have to be watertight as per the real think! Even in a rough sea very little water is coming in and that is from the hinge!
 Also I'd like to state here that the model I'm building right now is not the one in the pictures in the begining of the log! Here is some pictures form the real one that's being modelled! KERKYRA is going to be the next one!
bassplayer1
Re: Open type ferry
« Reply #49 on: April 08, 2014, 09:30:24 pm »
So, here is today's progres! While waiting for some styrene sheet to come through the post I made the funnel! Made a plag out of balsa and then pressed it on a piece of styrene heated in the avon! Also I taped all the tamplates together to get a rough idea and I found out that some adjustments are necesary! Good job I went that route before I started cutting on the final material ok2
Pages: 1 [2] 3 4 5 6 7 8   Go Up
Page created in 0.134 seconds with 22 queries.
