Author Topic: Starting With A Coble  (Read 3015 times)
Scho
« on: December 27, 2012, 07:49:35 pm »
Hi there new to the hobby and have just placed my order and awaiting delivery of a Northumberland Coble hull from Orion Mouldings.
http://www.orionmouldings.com/apps/webstore/products/show/3254192
I plan to "fit it out" (is this the right term?) as a potting boat with an electric motor.
Can anyone point me in the right direction to get hold of some 1:12 scale deck crew and lobster pots if possible?
SailorGreg
Re: Starting With A Coble
« Reply #1 on: December 31, 2012, 11:52:39 am »
For the accessories you could try Macs Mouldings www.macsmouldings.co.uk although I couldn't see lobster pots on a quick look.  For 1/12 figures the ones produced for lifeboat crew might work (although fishermen rarely wear lifejackets while the RNLI, as you would expect, are red hot on that). Try Speedline Models www.speedlinemodels.com or this thread here http://www.modelboatmayhem.co.uk/forum/index.php?topic=10396.msg331246#new.  Or e-bay or Amazon are always worth a try.
Hope that sets you on your way.
Greg
Guy Bagley
« Reply #2 on: December 31, 2012, 02:09:58 pm »
i have done one of these..... they make a lovely interesting model....- you can get figures at 1 to 12th or 1 to 10th scale from cap maquettes in france, they're costly but great.....
i also second the  macs mouldings comments- great for fittings,
my  lobster pots i got from marks model bits.......
Guy Bagley
slug
« Reply #4 on: January 01, 2013, 06:13:07 am »
bosun models does a pot hauler, 1/12 scale plus other bits ....tony
Scho
Guy Bagley
« Reply #6 on: January 03, 2013, 10:43:26 pm »
yup its mine.... O0
Guy Bagley
« Reply #7 on: January 03, 2013, 10:44:28 pm »
you can also get a pot hauler from waverley models too....
slug
« Reply #8 on: January 04, 2013, 06:12:10 am »
the range shops do foam balls,various sizes could be ok for round fenders and pot markers tony
cobleman
« Reply #9 on: January 04, 2013, 02:54:44 pm »
Hi scho i build model cobles in mahogany to date iv built 36 no plans good luck with yours .  cobleman
Scho
« Reply #10 on: January 07, 2013, 07:59:13 pm »
looking into fitting a motor and controls etc, being completely new to this i am unsure of what motor, coupling, propellor to go for. Also where is best to fit the motor and drill the shaft hole in the hull. are there any how to's out there that could possibly help?
Guy Bagley
« Reply #11 on: February 02, 2013, 05:51:22 pm »
if its of any help i use the most straight forward set up going, a simple 545  ( 5 pole low drain motor ) i use a standard huco coupling and a small 35mm 3 blade brass prop... everything is powered from a 7.2 volt nicad... runtime is about 50 to 60  mins from a 3500mah pack... i actually have 2 batteries in the boat just for ballast reasons....
tt1
« Reply #12 on: February 02, 2013, 09:12:31 pm »
The round fenders similar to Guys I believe can be got from Andy, i.e. Models by design.
