Over the holiday period I have been banned from any building work on the big boats I have on the slips.
HOWEVER I can't be banned from playing with my Christmas presents !! These are nealy all drawings of lifeboats from the RNLI that I didn't already possess and amongst them was two drawings of the 18ft 6in McLachlan Class Lifeboat, a small boat used as an inshore rescue craft prior to the introduction of the Atlantic 21 class. Very few were built and when the Atlantics went into service some became boarding boats for large ALB's (Aruns etc)which were kept afloat. One of the class has been preseved in the National Collection of Lifeboats at Chatham Historic Dockyard.
So I scanned the drawings, which are 1/8th scale, and reprinted them at 1/12th scale. As the boats had twin inboard/outboard drives and no way of making scale ones to fit ( commercial ones are too expensive and too big!!) I decided that the answer was to emulate the old Lesro Atlantic 21 kit and fit a single prop on the centreline and use the outdrives as rudders. This means that when on the water it looks OK and doesn't look too bad out of the water. A check of space available below the cockpit floor showed that a Speed 400 and a 30mm prop could easily be fitted.
A ply keel was cut and the propshaft inserted and glued in place.
As the drawing does not contain a set of lines the frames were made using the sections given, with a little 'lofting' where needed, to produce an acceptable shape.
