Yes well aware of spectra and dynema and the joys of braiding lengths of it back together
I have quite a few hundred metres of both here in fact ! mostly bought in the nineties / naughties
from 35 Lb for indoor flying / zero wind flying of icarex ultralights through to 500Lb breaking strain
for my big Parafoils (dual and quad line kites for buggying) I've been a kite maker and flyer for around
40 years - it used to be cheaper than RC
because of the difficulties (by design) in knotting either line type I don't consider it really the most effective
for mast rigging, and hence I use 130 Lb break "climax" bridle line :
http://www.climaxlines.co.uk/which can be both knotted and heat sealed .
it also has the advantage that if you want to mark off a preset position you can "pick" the white inner through the
black outer, "flash" it with a lighter leaving a white marker, with no appreciable loss in overall strength.
I agree though the rigging supplied with the yacht was VERY inferior, but the brass rod arrived in the post today
so by bedtime tomorrow I will have rock solid, nylocked and threaded spreaders that will resist falling off by design
the mast being "pill-shaped" in cross section does have a tendancy to bow and with the aluminium crane can actually be
a bit top heavy
Dont know if thats what contributes, but its history now ! :)
regards
BB
who is measuring up for a new "suit" of sails or three - dont like the printed artwork on the stock sail
