GUYS
is polyester as good as epoxy resin to coat the inside of a wooden model ? poly is a lot cheaper , will IT hold on as good ? crack if it gets knocked ?
i used gorilla glue mostly to build the model and am very disappointed with it
[size=78%],[/size]
its great till you scrap of the access then it has no strength and is full of air bubbles like foam ( GOOD ON GARDEN GNOMES
[size=78%] )[/size][size=78%] [/size]
[size=78%]so now i have [/size]
cleaned[size=78%] the in side up i want to coat it about 1/4 inch thick in the bottom with a resin [/size]
[size=78%]and then put a thin sheet of FB cloth on the out side [/size]
[size=78%]way is [/size]
epoxy[size=78%] the [/size]
preferred[size=78%] resin ? is it [/size]
easy-er[size=78%] to use [/size]
[size=78%]thanks BOB [/size]
