Pages: 1 [2] 3   Go Down
Author Topic: Dumas Carol Moran 1/72 scale  (Read 16264 times)
Tim B.
Re: Dumas Carol Moran 1/72 scale
« Reply #25 on: January 18, 2013, 02:59:22 pm »
This one's Really shaping well, looking like the best job anyone's done on this kit, taking it past what Dumas had intended.
Bravo !
hazegry
« Reply #26 on: January 19, 2013, 01:17:36 am »
well went to the LHS and got a 3 blade prop it looks so much better than the 2 blade plastic prop that came with the kit.
hazegry
« Reply #27 on: January 19, 2013, 04:20:21 am »
did some detailing on some of the small bits and made my own eyelets since I lost a few out of the kit.
escipion
« Reply #28 on: January 20, 2013, 03:33:29 am »
Hello!!!
Looks great that propeller
hazegry
« Reply #29 on: January 20, 2013, 03:47:18 am »
it better for 20 bucks lol
I made a bunch of little dogs out of .05mm brass and glued them on the doors
I think shes coming along as soon as my little drill bits get here I will do the railings and paint the main cabin then everything can get glued on.
hazegry
« Reply #30 on: January 20, 2013, 04:44:31 am »
dressed up the manhole covers what do you guys think?
hazegry
« Reply #31 on: January 21, 2013, 01:15:37 am »
well just need to spray the lower cabin red the green is from spraying the underside of the roof. I am having mixed feelings about putting the lockers on the boat I may just leave them off.
hazegry
« Reply #32 on: January 21, 2013, 04:32:47 pm »
well I got the bottom cabin painted I just need to do some touch up around the lip and paint it white. I haven't glued anything to the cabin yet because I don't want to make putting the railings on difficult. (my drill bits for that haven't shown up yet.) well heres the pics.
escipion
« Reply #33 on: January 21, 2013, 04:45:58 pm »
 Hello!!!!
Nice work, I’d got into more work because first build the cabin with the rails, and then painted it.
I’m following with attention your project  :-))
Best regards
« Reply #34 on: January 21, 2013, 05:03:34 pm »
Just love your green hull colour and I definitely want it for my Tosher build. Which brand is it please?
hazegry
« Reply #35 on: January 21, 2013, 05:09:59 pm »
its testors Model Master FS 34102 Medium Green it is enamel I read somewhere it reacts badly with other brands so you may want to test it first to be sure it will work.
« Reply #36 on: January 21, 2013, 10:15:01 pm »
Thanks for the information. If I can get it I will stick to one brand.
hazegry
« Reply #37 on: January 21, 2013, 10:57:42 pm »
I got the white trim painted around the cabin it really sets the boat off.
hazegry
« Reply #38 on: January 22, 2013, 03:30:00 am »
little more detail added.
hazegry
« Reply #39 on: January 23, 2013, 03:21:26 am »
well I couldn't put it off anymore so I soldered up the railings tonight it took all day I had surgery on my Jaw today so moving a bit slow, but I think taking my time paid off every joint is clean and doesn't need clean up work.
tugmad
« Reply #40 on: January 23, 2013, 09:44:55 am »
Well here she is my finished1/24th scale Moran tug the, Miriam moran,  now all I need is some ice  free water to try her out on
Sorry for butting in again  Hazegry your build is looking really great   :-)) :-))
tt1
« Reply #41 on: January 23, 2013, 02:43:32 pm »
Really nice builds gents, following closely. Nice to see the railings template in a kit, not seen one before - was it accurate hazegry?
                                        Regards, Tony. :-))
hazegry
« Reply #42 on: January 23, 2013, 03:19:49 pm »
from other threads I have read its accurate I will know if it is or not when my drill bits get here and I can fit it to the deck but when I hold it up to the deck now it looks good. Tugmad post away you really did a great job on your tug thanks for sharing.
hazegry
« Reply #43 on: January 23, 2013, 10:34:05 pm »
well the railings are on and the pattern worked out real well took a bit to get it finished but I think it looks good for my first time doing railings.
« Reply #44 on: January 24, 2013, 02:46:24 pm »
They do add something.  Nice work.   :-))
Ken
hazegry
« Reply #45 on: January 25, 2013, 04:11:16 am »
ok I pickled the railings what is it you ask you use copper etching solution and etch the railings this helps the paint adhere and makes it less likely to pop off. heres how David Merriman explained it to me
copper alloys are poor substrates for paint adhesion. Pickling is the
process of introducing microscopic pits by acid/alkyd attack. Once pickled, you rub off the excess oxidized metal (do not sand or polish) and lay down the primer. The primer will stick very, very well. Don't do this and the primer-paint will eventually shrug off the work.
Brush on the Ferric Chloride and scrub it into the metal with the
brush till the metal darkens a bit. Then come back with fresh water spiked
with  a little baking soda, and scrub to kill the acid. Rinse with fresh water, dry,  and prime.
hazegry
« Reply #46 on: January 26, 2013, 03:34:59 am »
not much work done on the boat today but did get this.
hazegry
« Reply #47 on: January 28, 2013, 06:03:06 am »
railings are done
tugmad
« Reply #48 on: January 28, 2013, 07:48:55 am »
I must say that they look very nice too :-)) :-))
hazegry
« Reply #49 on: January 29, 2013, 10:50:31 pm »
well I got the hand rails done on one side and I got the electronics soldered up.
Pages: 1 [2] 3   Go Up
Page created in 0.096 seconds with 22 queries.
