For power I am thinking a brushless 1400kv / 550 watt motor with 40-50A ESC using a 3 cell LiPo. This might be overpowered but then I do have a throttle control. Rather run slightly overpowered at half throttle than underpowered at full throttle. This way no heat problems.
Scratching my head with mounting now and what length propeller shaft and size/pitch prop. Vaughan
Hi Vaughan,
As you mentioned, 550W is rather a lot for a model this size (26") and it will 'fly', when full throttle is applied, bordering on undrivable, as the angle of the propshaft will reek havoc with the running attitude (lifting the stern and pushing the bow down).
Close to 14000 rpm under load at the prop is way too much for a subsurface drive with a steep propangle...
Depending on which ESC and motor you have in mind (got a link?), be aware of the fact that most brushless motor/ESC combo's tend to run (very) hot when used partial throttle for longer periods of time.
I managed to fry a motor with in a minute; the motor (a two pole inrunner), was too hot for the boat in question, making it impossible to get beyond half throttle without flipping the boat, after a few half throttle runs the motor overheated and smoke poured out of the hull.
The ESC was also very hot when the boat was retrieved, but the motor was the first to give in.
It's better to select a motor with a Kv that will run mostly full throttle, giving the boat a scale(ish) speed.
I use outrunners, as these tend to have more suitable Kv for scale boat purposes; mounted on a watercooled mount, the heat build-up is manageable, even at partial throttle.
A car ESC usually works better than a 'marine' one, better low end response.
Regards, Jan.
