Hi all
Go gentle, new starter here....
I am starting to accrue components to start my very first foray into model boat building but have come across an issue I am not sure if is normal or not.
I have got a 10" JP Accesories Prop Shaft, M4 threads both ends, 6mm Diameter tube etc etc, and also a plastic 3 bladed M4 threaded propeller.
When I screw the propeller on to the end of the shaft it tightens but there is still 5-8mm of thread left showing.
I have just been into my local model shop and been told that i need to cut back the threaded end of the shaft so that the prop tightens onto the nut and washer next to the bearing, something about not transferring the loads through the motor?
He walso went on to say that the other end that connects to the coupling isnt as important and is fine to have some threads on show providing it has a good connection to the coupling.
Is this correct?
Can someone maybe go through thte basics of Prop - Shaft - Tube - Coupling - Motor connections with me?
Many thanks in advance
